Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Brushes will not move
Everything works but brushes will not rotate
  • Hoover Master
  • 1,534 Answers
Try to turn the brushes by hand. If they won't turn remove the brush assembly to see if it is seized, if it is, take it apart and clean the brushes and the gears. If it is nor seized the turbine might be seized.
Posted on Jan 27, 2014
Model UH70086 agitator brush won't rotate. the belt is fine and turns the wheels. replaced v belt because I thought it was stretched but new belt is the same size. everything turns, the belts and the...
The brush has to be able to rotate freely in order to work. If you remove the roller and its end caps you may find it is clogged with hair or other debris. Cleaning out the debris should allow the brush to rotate freely.
Nov 05, 2013 | Vacuums
Cleaning brushes wont rotate
I understand how important the brushes are when cleaning.
You may want to the check the pump belt for breakage for the brush belt and pump belt work in conjunction with the pump.
If you're still experiencing difficulty, you may want to have your machine inspected at one of our Authorized Service Centers. Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 17, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
I have a Dyson Telescope vacuum. Everything works fine, except the attachment used for floors. I can feel air and suction going through the attachment, but the brush doesn't rotate or move at all....
If you have suction as you say, the tool is faulty.
They come apart so you can clean them. remove all hair and debris from the roller brush (use a coin to split it using a quarter turn on the two/three screws). Try turning the brush with your fingers. If it is stiff, it needs attention to the bearings in the tool probably. If it turns OK, then the mini turbine inside is faulty -- replace the tool.
Feb 05, 2011 | Dyson DC14 Telescope Reach All Floors...
My brush won't rotate. i have replaced the belt once already but it melted because the only thing rotating was the motor pulley. I have cleaned all the excess hair off the brush, checked everything, and...
The most probable cause is improper tension on the belt. What would cause this problem is the wrong belt, or improper adjustment of belt. Once installed, the belt should only move slightly when pushed down by your finger. Too loose and the belt won't rotate the brush and will quickly burn out. Too tight and it will cause excessive stress on the motor and shorten it's lifespan.
Another problem could be that the belt wasn't centered properly. When the new belt is installed, the brush needs to be manually rotated a few times to center it. This will prevent it from getting caught in or on a part of the power head, thus quickly breaking or melting.
If you still have problems you may need to take it to a reliable service center.
Dec 21, 2010 | Bissell 3576 CleanView II Bagless Upright...
I have an Oreck XL2 and the brush is not rotating.
First, check to see if the drive belt for the brush is broken. If it is you need to get it replaced. Also, remove the brush from the cleaner and clean if of all debris then check the small caps at both ends of the brush. If they do not move freely, add a little WD40 and rotate by hand until they move freely. When putting the new belt on or replace the old one, be sure it is put on properly so the brush rotates in the right direction.
Sep 15, 2010 | Oreck XL2200 Bagged Upright Vacuum
I have a Hoover Steam Vacuum, All Terrain, and the bristle brushes are not rotating. They appear to be seated properly and, the entire vacuum is clean and free of lint, hair etc., so everything is working...
I checked the owner's manual and the parts breakdown for your model F5807. Both showed that your model has a stationary brush strip and not rotating brushes. Is F5807 the correct model number?
May 18, 2010 | Hoover F5807 SteamVac Wet/Dry Vacuum
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Brush roller will not turn when I star to sweep.
maybee there is hair in it, do u know how to fix a psp that doesnt read games
Jan 15, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Furniture attatchment
On the attacment there is a slide move slide either up or down for brush to rotate.
Mar 08, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
85 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
