Question about Epson Stylus NX400 InkJet Printer
Reset ink cartridges - Epson Stylus NX400 InkJet Printer
How do I reset my Epson T200XL ink cartridges?
Resetting the Epson Ink Cartridge Chip With Software A freeware program called SSC Service Utility enables users to download and install software that helps to manage their Epson printer. The software offers several functions, one of which is resetting the ink cartridge chip. Other settings allow users to freeze the internal ink counters or to reset the internal ink counters. It supports over 100 Epson printer models, but some printers may not respond to the commands from the software.
Using a Cartridge Reset Tool A cartridge reset tool is a small plastic piece that fits against the cartridge. The contacts on the reset tool correspond to the contacts on the printer's ink cartridge. When connected to the ink cartridge, the cartridge reset tool indicates the resetting of the ink cartridge with a green LED light. The reset tool is beneficial not just for resetting the chip, but also for allowing the printer to use all of the ink in the cartridge.
Troubleshooting Issues With the Reset Tool
Buyers should be sure to check the description for each reset tool carefully to determine whether they can reset their Epson printer cartridge with the tool. If the wrong cartridge is attempted or the reset tool is simply unable to reset the cartridge, users see either a red LED light or no light at all. In some cases, they simply cannot reset the chip any further. Before disposing of a reset tool, always test it on multiple ink cartridges.
Apr 07, 2016 | Epson Office Equipment & Supplies
Reset ink cartridge
Unfortunately you can't....
The ink level indicator cannot be manually re-set in the newer HP, Lexmark or Dell integrated ink cartridges, thus making it not usable. The OEMs all leverage 'fusible links' in the nozzle plate (internal to base of ink cartridge) which physically blows the resistors as the original ink is consumed...thus resetting the ink cartridge's ink level monitoring capability is simply not possible. The ink tracking feature is only available with a brand new ink cartridge.
However, losing this feature is not necessarily significant, because the ink level indicator usually has 20%-30% ink remaining when it shows "low on ink". Therefore, the warning has limited value, because customers who prematurely replace their cartridges when they see the "low ink" message are wasting a lot of residual ink.
Refer to any of the following videos which cover this 'low ink' subject in detail:
http://inkjet411.com/?page_id=396 (HP 60/61 Low Ink)
http://inkjet411.com/?page_id=517 (HP 74/75 Low Ink)
http://inkjet411.com/?page_id=598 (HP 901 Low Ink)
http://inkjet411.com/?page_id=1261 (HP 92-99 Nuisance Messages)
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jun 11, 2013 | Office Equipment & Supplies
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 20, 2010 | Office Equipment & Supplies
How to reset printer canon 8180
1.Attain an ink cartridge chip resetting device from a computer electronics retail store or an online retailer. These portable devices resets the cartridge chip so your printer recognizes the cartridge as being full.
2.Remove the cartridge from the printer by opening the top tray and taking the cartridge out of the carrier holder.
3.Line up the pins on the resetting device and the chip on the ink cartridge, then connect them together, making sure the connection is firm.
4.Hold the resetting device and ink cartridge chip in place, for about 10 seconds, until the LED light on the device turns green. This means the cartridge was successfully reset. Afterward, remove the device from the cartridge.
5.Place the cartridge back in the printer's ink cartridge carrier holder and print a test page.
Dec 18, 2010 | Canon imageCLASS MF8450c Color Laser...
Refill cartridges - need to reset ink level monitors
I must tell you that Dell uses sensors in the ink cartridges and the printer. So one the ink cartridges is low on ink, sensor on ink cartridges will show as low and if you get it refilled, there is no way to reset the sensor to full since Dell does not want customers to use Refilled ink cartridges. However if you are looking for Low cost ink cartridges they I would suggest you to purchase Standard Capacity ink cartridges from www.dell.com/supplies. they are almost half the price for hi capacity ink cartridges.
Nov 06, 2008 | Dell 922 All-In-One InkJet Printer
Continuous ink supply system for epson r285. Printer will not recognise the cartridges as full. have used the reset button on the cartridge but still no luck. any ideas?
Resetting the Epson Ink Monitoring System -
Even though the CFS maintains a constant level of ink in the cartridges, the Epson monitoring system will signal that the cartridges are empty after a cartridge full of ink has been used. This ink level information is stored on the Intelligent cartridge chip. These cartridge chips have to be reset with out lifting the cartridges. This is done with Inksupply.com Auto Reset Chips. On older Epson printers, before the Intelligent cartridge, it is done mechanically by removing and re-inserting the Inksupply.com switch activators. CFS cartridges must be reset without lifting them.
Previous Reset Methods -
The resetting methods have evolved over the past couple of years. First the Swedish Reset method was used, then the Equalizer Program, then the F-16 Chip Resetter, and now the Auto Reset Chips.
Hope this helps you. Good luck!
Oct 23, 2008 | Office Equipment & Supplies
Ink low error
Hi there the ink cartridges are designed to be used once. Most of these new ink cartridges have a set chip on it once you have installed a new cartridge it registers that a new one has been installed and resets the ink counter for that cartridge. When you refill the cartridge it doesn't reset the chip.
I don't know how to reset the chip but the best suggestion I can offer is to purchase a compatible cartridge that has been reset.
Thanks J
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
