Question about Imation (01946) External Floppy Drive
Data transfer I have LS 120 Imation super disks with data stored, but no drive to read them. Do you know of a service that can transfer the data from the super disk to a standard floppy, cd, or dvd?
    Sergeant:
    Champion:
  • 317 Answers
Usually your local Fry's, Staples, Office Depot could do the job for you (or even a local PC Tech).
Posted on Dec 10, 2007
  • Baja Data / Jay Arias-Chavez
    Was your problem solved? Do you have more information or questions?
    The more information you provide to us, the better we can help.
    If the solution was good, please rate it accordingly! :D
    Thanks!
Imation 11795 driver WindowsXP
IMATION stopped making the "LS-120" (Laser Servo) drive many years ago, when USB-interface memory-sticks became cheaper & faster. Imation did have parallel-port device-driver software for Windows 95/98/ME, but never updated them for Windows NT/2000/XP.
Instead, disassemble the case, and you will find an IDE-interface Imation LS-120 drive inside. Connect the same "smaller" 4-pin power-connector that used to connect to a 1.44 Mbyte 3.5-inch diskette, set the "master/slave" jumper, and connect an 80-pin IDE ribbon-cable, and connect the other end of the ribbon-cable to an IDE socket on the motherboard.
Jul 06, 2014 | Imation Superdisk Drive 120mb Parallel...
I need a driver for Windows XP and Windows 7. I have the parallel port version of the LS120 drive, brand: Imation It seems that nowadays this is almost impossible. I found one site that asks me to pay...
You might consider downloading a Linux LiveCD (such as Knoppix), boot to it, and see if Knoppix detects the LS-120 when connected to the legacy computer via parallel port. Make sure that the parallel port is enabled in the BIOS. From there, you can transfer the content from the disks to a flashdrive or external hard drive. My assumption is that you want to retrieve the data that are on these disks. In most cases this ancient hardware should be deprecated once data retrieval is complete. From my experience, the Knoppix DVD is more compatible than the CD version.
Paul Ronco
Jan 29, 2018 | Imation (11762) LS-120 (SuperDisk) Storage...
I have a very old Imation superdisk drive, 9" by 6" size. And I can't find a driver to download
If it is the "internal" Imation SuperDisk drive, then set the drive's "master/slave" jumper (just like you would set the jumper on a disk-drive or CD/DVD drive), and connect it to one of the IDE ribbon-cable connectors (which usually connect disk/CD/DVD drives to the motherboard).
No additional drivers are required, in the above configuration.
Jan 23, 2010 | IBM SuperDisk (05K9235) Internal LS-120...
Apparntly I have DRLS120 SUPER DISK DRIVERS ON MY COMPUTER AND I CAN'T VIEW MY 2HD 1.44 MB FLOPPYS USING MY 31/2" FLOPPY DRIVE. How do I remove these drivers so that I can use my floppy drive?
If functioning correctly, the hardware of the Imation LS-120 devices can read/write 1.44MB diskettes, using "magnetic" hardware, and can use the built-in laser to read/write the proprietary 120MB "SuperDisk" diskettes.
What problem do you have?
How about taking the diskettes to a friend's computer, along with a USB memory-stick, and copying files from the diskettes to the memory-stick?
Oct 31, 2009 | Computers & Internet
IMATION Super Disk. MODEL No SD USB M3. SERIAL NO 10152 16632A
Define "no tworks"?
When you insert a disk, do you hear it spinning?
If it does spin, does it transfer any data from the disk into the computer?
Aug 21, 2008 | Imation (01946) External Floppy Drive
Flasyh drive problem
It seems that it's about to "die".
So, my recommendation is that you buy another flash-drive,
and copy all the files from "old" to "new",
and then take a hammer to destroy the old drive (and the data on it).
Jul 21, 2008 | Imation (11762) LS-120 (SuperDisk) Storage...
imation super disk SD-USB-M2.Solution to run under Vista service pack 1.Works for me
boot up your puter then plug in the imation super disk into your puter's usb port then into your power sulpply socket.Then if you have a reset button on your puter Press it
the puter then shuts down and resets itself when the screen appears it asks "Start up normally" Press enter.The drive is recognised and works.Its a bit of a ball ache but works for me.Hope this helps others with the same problem
JM.
Jul 12, 2008 | Imation (01946) External Floppy Drive
LS 120 Super Disk 120 MB Imation
hey there,
all i can say You make it a point to stay on the cutting edge of IT, so it's only fitting that your next support call is for a cantankerous old floppy drive. You're as far from the cutting edge as you can get, but can you still find the fix?The floppy drive is...
Feb 04, 2008 | Imation (11762) LS-120 (SuperDisk) Storage...
Imation LS120
My computer has such a drive (120 Mbytes/disk).
As a "random act of kindness", I will read them, and burn the files onto a CD-R. Reply to this message, if you wish to proceed.
Oct 17, 2007 | Imation (11762) LS-120 (SuperDisk) Storage...
Imation (01946) External Floppy Drive Logo
100 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
