Question about Insignia Solutions NS-24E200NA14 24" LED TV 1366x768, 60 Hz, HDTV
CAN'T GET THE SET UP TO GO ALL THE WAY. IT GETS STUCK ON CHANNEL SCAN. REMOTE WON'T TAKE IT ANY FURTHER
HOOKED THIS UP TO THE SAT BOX BUT CAN'T GET THROUGH THE SET UP. REMOTE DOESN'T WORK ALL THE WAY. STOPS AT CHANNEL SCAN AND WON'T GO ANY FURTHER. CAN'T GET ANY PICTURE OR SOUND.'WHAT SHOULD WE DO.
  • Insignia Sol... Master
  • 10,137 Answers
Ask Best Buy technicians. Insignia is their house brand built by LG.
Posted on Jan 06, 2014
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
How to change channel from one to any one channel in sony bravia
I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No remote. How do I reset the menu or channel programming? Using sat box, but can't get the TV to channel 3.
You best bet really is to locate an original and not a universal remote for the set
Apr 08, 2012 | Televison & Video
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
TV was hooked up to cable and it only gets 3 channels, how can I get the rest of the channels?
if your tv has the digital tuner and you want to use a antenna, select the customer menu either from the remote or from the front of the tv if available then select the channel scan or channel program settings, this will set the available channels into the tv memory, if you have an older tv(no digita tunning) you will need a digital converter box(avail thru most electronics stores or elect. dept. stores for about 40 dll) you will need to program the box but most of these boxes have a good on screen detailed description on the setting up procedure.
Aug 20, 2009 | Televison & Video
Can't get satallite channels
If you are on Satellite then it only works off of channel 3 and you will not get any other channel on the tv set. But you will need to turn your sat box remote to change channels.
Feb 27, 2009 | Televison & Video
Please scan channels
try hitting the input button or go to channel 3. the sat box can only output to channel 3 or 4 or if using Dish network try channel 66 or what ever the channel it outputs. it also can output via video cables so check each video setting on the set. make sure the box is on first.
Dec 23, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Insignia Solutions NS-24E200NA14 24" LED TV 1366x768, 60 Hz, HDTV Logo
78 people viewed this question
Top Insignia Solutions Televison & Video Experts
Tom Chichester
gemagm
Brian Coughlan
Are you an Insignia Solutions Televison and Video Expert? Answer questions, earn points and help others
