Question about Ingersoll Rand HD Air Twin Piston Straight Line Sander - 2-3/4
Ingersol rand board sander wont work once preesure is applied
Sander runs fine under no load . as soon as it toches workpiece it stops
SOURCE: ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
  • 1388 Answers
SOURCE: compressor runs loaded continuously even in low/no demand periods
Each compressor should be checked several times per year as to length of time it takes to fill an empty tank to set pressure. This will provide chart of performance / efficiency. I believe that compressor #2 is not running to full capacity. If compressor # 2 is suffering from leaking valves or headgasket the head and air discharge temp will higher than compressor #1. Good luck!
Posted on Oct 18, 2009
  • 243 Answers
SOURCE: my tow behind air compressor ingersoll rand 185
press load button or toggle switch
Posted on Feb 08, 2010
How to assemble an ingersoll rand sander 315
Gear timming in line sander
The above link may help as the unit is similar to the Central Pneumatic Straight Line Sander
Mar 02, 2015 | Ingersoll Rand Ingersoll-Rand IR 315 Heavy...
Sander won't shut off
Most likely the throttle valve is stuck open. On sanders usually sanding debris has coated the throttle valve pin, causing it to stick. Other times the throttle valve seal has worn and needs replacement.
Mar 17, 2014 | Ingersoll Rand 311a Air Dual Action Quiet...
SANDER RPM IS LOW , EVEN AFTER MAX AIR SUPPLY
Turn dial on side,or on bottom of sander should change rpm.
Sep 19, 2012 | Ingersoll Rand 313A IR-313A 7"Dia 5000RPM...
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
The trigger does not work
the trigger valve is either ****, the o ring worn or the spring broken, remove trigger valve from the bottom of the handle, usually by removing the air intake
May 10, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
Check tiny allen head grub screw has not loosened on bottom trigger button and is catching on housing, otherwise one of the o-rings is missing off trigger plunger or piston. Carefull of spring behind trigger button when loosening allen grub screw. You will find the plunger behind trigger button.
Apr 22, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
Wont work under any load. wont restart when load is taken off. its brand new. have 13 cfm, 100psi
If it's new, it may be too tight yet. Put a bit of oil into the air fitting and run it under no load. It may start to run faster as it wears in and the oil goes through it. After running it for several minutes, try it again and see if that works.
Nov 29, 2009 | Ingersoll Rand HD Air Twin Piston...
WHAT OIL IS RECOMENDED FOR IR315 STRAIGHT LINE AIR SANDER
I just use my regular air tool oil on mine, have several of these IR longboards. Rick
Mar 20, 2009 | Ingersoll Rand HD Air Twin Piston...
Ingersoll Rand  HD Air Twin Piston Straight Line Sander - 2-3/4 Logo
252 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
