Question about Whalen Furniture Windham Fireplace TV Console
Temperature control I do not know how to set the temperature control to get the heat to turn on on this Fireplace TV console. Also, where can i order a replacement remote? The remote to my fireplace was not included with my unit. thanks
    Scholar:
  • 27 Answers
If you go to this website they can assist you with getting technical assistance on diagnosing your issue and getting a remote for you. Hope this helps. http://www.rick-horwath.com/Whalen_Windham_Combination_Electric_Fireplace_Heater_Manual.pdf
Posted on Jun 18, 2014
I have a Jensen TV and a remote controlled fireplace in a new camper. when I turn the volume up and down on the TV the fireplace goes on and off
Set it up with an other code said to TV. This will rectify the problem. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 21, 2014 | Televison & Video
Majestic gas fireplace troubleshooting
Is your log set remote driven? Do you have the room temperature set in it? You may have inadvertently set the room temperature for a certain range. Or you may have a thermopile going bad. Do you have any other remote driven appliances affected at the same time? I.E.: Do you change tv channels and the logs go off?
Dec 05, 2013 | Home
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
Dont know how to start it, dont know what it needs to start, and there is no remote to it
Some units sometimes have a wall switch that has to be turned on.
Usually on the bottom of the fireplace bheind the grille is the control
box a switch to turn on the electric heat and another to control the
electric heat and a possible blower.
Check to make sure the breaker is not turn off.
Feb 10, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Heat n Glo electric fireplace w/remote just stop working.
throw it out on the street when a bus runs over it file for insurance and get a new one. tell the insurance company you where having a city bonfire in your front yard and the bus jumped the curb. You know city slicker folk in those tall buildings don't know any better.
Mar 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Wall mount for 52in tv ?
Here is a mount rated for your size TV http://www.bhphotovideo.com/c/product/518312-REG/Bentley_PLAW_6000FB_PLAW_6000FB_32_60_Flat_Panel.html
Also, be VERY careful mounting ANY plasma above a fireplace. Plasma sets are typically convection cooled to avoid the noise of fans. The heat from a fireplace will GREATLY reduce the life of the set. When people I know insist on putting a set above a fireplace I usually insist they install a cooling fan with ducting that will vent fresh air to the set. If you are concerned about the temp of your set simply consult the owners manual for operating temperature and measure the air above the fireplace yourself. BHphotovideo.com typically has good prices on mounts along with amazon. most other places like bestbuy or circuitcity will stick you on the price of the mount because they make their money from accessories. Also, why did your last set die? plasmas are typically rateed for 10+ years, did yours over heat and start to change colors?
May 17, 2008 | Televison & Video
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Loss of the color Red....Possibley others on my plasma
If you are lucky, it could be an open resistor or defective IC. Otherwise, I see a new TV in your future as the Plasma display would cost nearly $5500 for the part alone. If the fireplace is used much, I would not mount a TV above it, especially a plasma set which generates a lot of heat all by itself. If the fireplace is only used occasionally and you want to put the replacement set in the same spot, then I would consider a LCD model instead.
Jan 10, 2007 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Whalen Furniture Windham Fireplace TV Console Logo
234 people viewed this question
Top Whalen Furniture Home Experts
Donni Steen
Tom Chichester
Are you a Whalen Furniture Home Expert? Answer questions, earn points and help others
