Question about Toys
Mr. Christmas Stepping Santa on Ladder. Why doesn't he climb anymore?
Only lights and music working. The instructions say the sensor in the right palm should be in up or down position, but this did not solve the problem.
  • linda grimsrud
    linda grimsrud Jan 14, 2016
    Do they all have a switch under the head?
2 Suggested Answers
SOURCE: I have a lifesize grinch
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
Posted on Dec 18, 2010
Testimonial: "Thank you so much,I would never have figured that out..... Peggy !!!!!!!!!"
2007 dodge durango p0123 and p0068
Code P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH and code P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION. Without having the vehicle to properly test, and based on the information I have it sounds like your throttle position sensor has kicked the bucket. Replacing the sensor with a new one should solve your problem.
Nov 07, 2013 | Cars & Trucks
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
Touch screen not working I have reset but screen not working
u have to go any repairing shop n show it then they will set its chip which is internaly connected with ur palm
May 10, 2010 | Palm Zire 31 Handheld
My palm treo is stuck on spanish and I have no idea how to change it back to english.
The only way to reset this to english is by performing a Hard Reset. It will remove all information on the phone BUT after it reformats it gives you the option to select English or Spanish.
The hard reset is performed by following the instructions below:
Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
Let go of the red phone button when you see the Palm screen.
Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
That should solve your problem! Hope this helps!
Dec 24, 2009 | Palm Treo 650 Handheld
Red light far right blinking continuosly (#26)
Hi jason,
The flashing red light indicates tha _something_ is not positioned correctly. Please check and see if you can find the sensor(s) that determine whether or not the components are correctly positioned.
You might also try unplugging it for 10-20 minutes to allow any electronic sensors to reset when you reconnect power.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Nov 23, 2008 | Gaggia Syncrony Compact Coffee...
Palm tx transfering music to device
Ptunes! It should have come with your TX software bundle, and it works with Windows Media Player.
  1. Rip your desired music to WMP. Keep WMP open.
  2. Connect your TX to your computer via USB cable.
  3. Open Ptunes on your TX.
  4. Select Sync from the ribbon at the top of your computer screen. Your TX should appear under devices in the top right. If not, click "Refresh Devices."
  5. Drag music from your WMP playlist to your sync list.
  6. Click Sync.
  7. Music should show up on your TX, ready to play.
  8. Click Stop Communicating on your TX before disconnecting from the computer.
To find your music in Ptunes:
  1. Open Ptunes on your TX .
  2. Click the music notes icon in the bottom right.
  3. Select from the folders displayed.
  4. Enjoy!
Please let me know if this helps.
For more information:
http://www.pocket-tunes.com/
Nov 18, 2008 | Palm TX Handheld
Expansion card
Has this card worked before in your Palm?
Jun 30, 2008 | Palm Tungsten E2 Handheld
Wii fit - jogging not responding
So once the problem is solved, here's the final verdict :P
Try this on the remote that stopped working.
Put the remote on your palm with the buttons down and with your other palm, without much force, hit the back.
It may sound ridiculous but sometimes the sensors block and need a little shock to get to work again.
Glad that your problem solved.
Jun 24, 2008 | Nintendo Wii Console
Oki 5600 & 3400 toners
This error is toner not recognized
Follow the instructions for possible fix.
INSTRUCTIONS TO CHECK REFLECTOR OPERATIONS
(1) Open the poly bag, and take out the Toner-cartridge.
(2) Remove the tape to the position like the figure.
Tape
(3) Hold the Toner-cartridge horizontally, so that the Lever-sensor may go up and down
vertically.
Lever-sensor
(4) When it does not see the Lever-sensor like the figure, turn the gear in the direction of the
arrow, and it tries to see the Lever-sensor.
Gear
(5) Return the tape to former position.
(6) Put the Toner-cartridge vertically.
(7) Move Lever-sensor like the figure.
Lever-sensor
(8) Confirms the Lever-sensor is returned smoothly.
Lever-sensor
(9) Repeat (7) and (8), 3 times. The Toner-cartridge is wrong when the Lever-sensor does
not work from the position of (7) or when it does not return smoothly
Mar 05, 2008 | OKI C5200n Laser Printer
I have also had the same problem, and I discovered that it may be caused by a little sensor in the headphone jack which enables the external speaker. Sometimes it gets stuck in the "off" position. Try plugging in and removing the headphones, that should solve the problem.
Jan 27, 2008 | Palm Tungsten E2 Handheld
Toys Logo
233 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
