Question about GE JEM31 Microwave Oven
I have a GE micowave/convection oven, Model JET342G-001. Worked perfect all the time until yesterday. After setting the time, push "start" and nothing happens. It makes a small sound like "click" and it does not start. However after time set is up, the oven beeps to let u know time is up. Any help?.
  • GE Master
  • 9,085 Answers
I would suspect a door switch is defective or its mount is loose, misaligned, or broken.
See my help file on door switches here.
Posted on Dec 28, 2013
SOURCE: GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Posted on Feb 28, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
najah
  • 180 Answers
SOURCE: Convection Oven has stopped working
magnetron may be defective . replace d magnetron
Posted on May 29, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Profile micowave model JE2160SF001 won't cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches:
There may be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden elsewhere, which is very helpful when troubleshooting, testing, and locating components.
Posted on Jul 25, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave oven push buttons not working no sound not functioning
You have a failing membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10950 and you can get it here for $89.59 (compared to over $135 from from GE!).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Oct 11, 2009
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the...
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Oct 25, 2017 | GE JVM1790 Convection / Microwave Oven
THE START BUTTON WILL NOT START THE OVEN, WE HAVE GE-JVM1790
the start button uses carbon pads and they could be worn out or not contacting properly you try and replace the control pads
Jul 26, 2010 | GE JVM1790 1000 Watts Convection /...
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Need manual for GE Profile
LOOK HERE;
http://www.serenitysys.com/******/archives/GE%20RV%20Microwave%20manual.pdf
Oct 16, 2009 | GE JE1640 Microwave Oven
When i push start on the oven nothing happens but the timer is wo
bad relay on control board . not worth it cost to high ( ge board 145.00 to 230.00 ) and with the oven @12 years old i dont think you would find it at price SORRY . please rate this answer , i need the rate to get my "wings' thanks
Jan 16, 2009 | GE Advantium SCA1001SS Convection /...
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Nov 07, 2006 | GE Advantium 120 Convection/Microwave Oven
GE JEM31 Microwave Oven Logo
121 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
