Question about Frigidaire Affinity ATF7000E Front Load Washer
The washer adds water and pumps it out but will no aggitate or spin.
  • carol hughes Dec 26, 2013
    wrong model,,,it is gltf1670SO
Hi
how could i change thermostat?
Posted on Dec 26, 2013
My washer does not spin after the wash cycle . model ge gcwp1000ww
It sounds to me like the timer could be defective. Thanks
May 02, 2016 | GE Washing Machines
Kenmore model # 110.23832100 Washer would drain but wouldn't spin or aggitate. Replaced coupler. Now will spin and agitate, but will not drain.
sounds like it's in the re-assembly since the water pump is directly connected to what you just did. take it apart once again and make sure all is put back right and water pump is properly seated on motor shaft.
Jul 15, 2011 | Kenmore 23822 Top Load Washer
I have a GE WJRR4170G1WW washer. Instead of going
Just wanted to let you know that the solution in the comments worked for my dishwasher!! Save me a service call and some cash!! Thanks Spencer.
Oct 06, 2009 | GE WBSR3140DW Top Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Kenmore model # 110.20722990
ck all motor connections just lean washer back against wall motor is right at front if motor ckd ok 2 things left motor or timer neither one is cheap but best guess would be timer
Sep 08, 2008 | Kenmore 24032\24036 Top Load Washer
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire Affinity ATF7000E Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
