Question about Plantronics Voyager Legend
My headset comes on but seems like its muted - Plantronics Voyager Legend
My whisper seems to be muted no one can hear me
Ensure that it isn't muted on headset and phone. Call us if you still have issues. Http://www.Motorola.com/contactus
Mark
Motorola Support
Aug 20, 2014 | Motorola Mobility Whisper Bluetooth...
My Plantronics Voyager 520 seems to be stuck in mute. I can hear others, but they cant hear me.
Try deleting the headset out of your phone and then re-pair it back up and see if that corrects the problem.
How to Pair the Plantronics 520 Headset
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
May 19, 2011 | Plantronics CS70 Wireless Headset
My hands free is on mute and won't come off mute .
Hi, Motorola H700 Wireless Headset does not go on mute, it might be from the volume control of the Motorola H700 Wireless Headset or from the cell phone volume control.
You can use this quick guide to know how to increase and decrease the volume control.
motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Hope it helped.
Have a nice day.
Mar 01, 2011 | Motorola Mobility H700 Wireless Headset
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
H500 mute problem?
I haven't heard of this before. Turn off it off and remove the pairing from your phone.
Turn it back on and pair it up again. Make sure you enter the passcode (usually 0000). That should fix it.
Jan 13, 2008 | Motorola Mobility Bluetooth Hands Free...
No voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
Plantronics Voyager Legend Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
