Question about DeLonghi EAM3400 Espresso Machine
Change quantity program quantity is not consistent
How do i use the dolce gusto i put a pod in of chocolate and the machine just kept going it wouldnt stop when tje cup was full
I'm not familiar with that model but oftentimes programming the quantity of water will involve pressing and continuing to hold the button down until the desired quantity of water has been dispensed. Next time you press and release the button and it should stop when that same quantity is in the cup because you holding the button last time has programmed it for that amount.
Jan 12, 2017 | Krups Nescafe Dolce Gusto
What is edc 03779
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes.
03779.....EDC ............ Rail pressure: Leakage in quantity compensation
03778.....EDC ...................Rail pressure: Leakage in overrun conditions
May 12, 2016 | Cars & Trucks
I seem to not be able to figure out the button sequence for programming the shots.
Try pressing and holding the button until the quantity is what you want it to be. Then try it again with just the normal short press to start. If it brews the same quantity as the first one then it is now programmed.
Jun 20, 2015 | Coffee Makers & Espresso Machines
Edc 03779 what's prombelm this
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes. some people have solve the problem with changing the fuel filter.
May 10, 2014 | Cars & Trucks
I have a Symbo LS2208 Scanner with a USB cable. The code is 39 I wan to program Shift + Tab and the tab key into the scaner. Here is the steps of what I want to accomplish. I have a window form...
give me the name of the program you curently use so i can try to see how i can convince it to move to the product code when you first scan.
Nov 28, 2011 | Symbol LS2208 Handheld
My Incanto Sirius coffee maker is acting strange. It automatically keeps brewing (1) large coffee. The only way to stop this is to shut off the machine. I am getting a LCD read out of Program quantity....
Program quantity is trying to program that amount.
When it starts to brew and gets to the quantity you want for that cup size push the brew button again and see if it stops.
Nov 21, 2009 | Saeco Incanto Sirius Fully Automatic...
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Steps to figure out formulas in excel
Hello this is Baris,
If you forget about the numbers and start naming your cells you can figure out your own formulas... Example :)
You buy apples, and you pay $2 per piece
in this case you have 2 numbers to find out how much you will pay.
price per apple
quantity
you have 3 apples you pay 6 dollars very simple right. 2 times 3.
Same thing in excel but this time you will just say price times quantity and excel will do the calculation for you.
Lets name your cells
Type in A1 Price
Type in B1 Quantity
Type in C1 Cost
Now, Column C is your calculation area.
Type in A2 2 (price for apples)
Type in B2 3 (quantity of apples)
Type in C2 =A2*C2 (price times quantity)
Now on, you don't have to calculate anything. You can change you price and quantity, cost will change by itself. Because the value in that cell is now related to other values in A2 and B2. I hope this gives you a starting point.
Sep 30, 2009 | Microsoft Excel for PC
Cannot program the machine....
Hi
To program the machine for brew quantity, Just hold the button down the whole time,(do not release) As it is dispensing liquid, when you get to the desired quantity, release the button. You can do this for each cup size.
Apr 25, 2009 | Saeco Incanto Classic Espresso Machine
Nuovo Simonelli VIP 2 group
Hold down the stop button and the continuous run button. lights will blink indicating program mode. Push one of the buttons that you are trying to program, when the desired quantity is reached press stop button. When all buttons are programed hit stop button again.
Jan 07, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
16 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
