Question about HobbyTron GYRO Hercules Unbreakable 3.5CH Electric RTF RC Helicopter
Remote will not control the helicopter
Got my son this helicopter for Christmas. Fully charged the Helicopter, and put in brand new batteries in the remote but the helicopter will not respond to the remote at all.
  • 4,006 Answers
Did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Posted on Dec 27, 2013
  • 3 more comments
  • James
    James Jan 03, 2014
    Thanks Russ. I did fully charge the helicopter. The light on the charging unit went from red to yellow and then to green. I actually charged it for about 6 hours because the instructions said the light would go off but it never did. I have confirmed that the battery in the Helicopter is working and I have tried 2 sets of brand new batteries in the remote but the red light (power on indicator) just keeps blinking and control of the helicopter is never achieved. Any ideas?
  •  Russ Hill
    Russ Hill Jan 03, 2014
    have you when charging had the control on and the elevator to the top. should not have any colours on while charging goes green when charged then goes off. try using a usb charger. these work better. and don't use the battery power. when you have just the lead into the helicopter the end should have a red light on it on the usb end. if not then there is now power coming out. if it has the led on then there is power but its not getting the right signal from the controller. try these things.
  •  Russ Hill
    sorry should not flash colours. only when its charged.
  • Kyle H
    Kyle H Jan 03, 2015
    Yea the battery is fine and I pluged the red cord in and it make the noise it just won't flash red to link with controler and are you saying there is another internal battery?
  • Kyle H
    Kyle H Jan 03, 2015
    It just goes solid red and in have no control and I have tried May time the start up process
Spinning
It's not fully charged. Try putting in brand new batteries and fully charge before trying again
Jan 05, 2014 | Brookstone Remote Control Helicopter -...
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four...
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Dec 28, 2013 | Shuttle 9094 Emax Remote Control...
Hi, the issue I am facing is that my remote is not able to connect to the helicopter. Earlier when I used to put the battery the light used to blink, now as soon as I switch on the remote it just does...
Helicopter should be powered off when charging. After fully charged (charging light as bright as it gets) and given 10 minutes to cool after charging, turn on helicopter first and place on level surface, this allows gyroscopes to sync up. Then, after making sure the main rotor control (left joystick) is all the way down, turn on controller, and quickly push left joystick all the way up (just until the blades move) and back down. This will link them. Also, make sure the antenna is still wrapped around the landing strut and not contacting any metal on the craft. And of course, good batteries in the remote, and ALWAYS let helicopter battery cool for 10 minutes after charging AND after flying. Also, NEVER fully drain battery, as soon as you cannot maintain altitude, land and power off. Fully discharging a Li/Po battery will weaken it severely, and sometimes kill it.
Please let me know if this helps, I love Syma helicopters, but they can be tricky sometimes...
r
Sep 04, 2011 | SYMA Toys industrial Syma S032 Ready to...
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
My son got a Halo UNSC Hornet remote control helicopter for Christmas. It was working great. Then on Monday Dec. 28 he tried charging it and it won't charge. What could be the problem? We have tried...
1.Check the battery of the Copter it seems to be dryied due to overcharging. 2. Check the charger, is it supllying the power or not to Charge the battery.
The solution is to change the battery with new one.
Jan 05, 2011 | NKOK Halo Hornet RC Helicopter
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
HobbyTron GYRO Hercules Unbreakable 3.5CH Electric RTF RC Helicopter Logo
999 people viewed this question
Top HobbyTron Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a HobbyTron Toy Expert? Answer questions, earn points and help others
