Question about Necchi 4595 Mechanical Sewing Machine
Have a Necchi 4595, need help
Doesn't always work well, can hardly use it. The darning attachment
doesn't work, seems it is the wrong attachment for machine.
Feeder is up, but cloth doesn't move smoothly or much. I have
to move material.
  • 65 Answers
Increase the pressure on the presser bar. Usually this is located right above on the top of the machine.
Posted on May 22, 2009
What are the numbers on the color coded needles
Needles made for different fabrics - are soft needle have a low number (ex.silk fabrics) and a hard needle has a high number(ex.canvas)
Make a test so you don't ruin the fabric or break the needles
god Luck
Jun 24, 2014 | Necchi 4595 Mechanical Sewing Machine
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Hi - I'm in the market for a sewing machine. I'm trying to decide between a Singer 4832C or a Necchi 3205FA. Which would u recommend? Thx.
I used to sell necchi's, I have used necchi's for over 30 years for sewing & quiting. I own a necchi model 4595 mechanical sewing machine, & a omega by necchi, model 6150, electronic, my husband does his quiting on it.I have made clothes & quits on both machines
I have never sold or tried a necchi 3205fa or a singer 4832c
all I ever had were old singers, which I have gotten rid of all them
make sure it has a operation manual with it.
make sure you can take it back if something is wrong with it.
happy sewing
Jul 23, 2010 | Singer 7442 Mechanical Sewing Machine
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
I have a necchi 4595, and well I cannot figure out the straight stitch....the dial doesn't show one?
It's just in the front panel, where the drawing of all the built in stitches are, it's the drawing number eleven from the left, you'll see a zig zag (red) and a straight stitch (black) Select A group of stitches (knob with the arrow) and then select the eleventh stitch (same knob but use the dial, look the manual) and then select zero on your stitch width dial. Hope that helps :)
Apr 23, 2009 | Necchi 4595 Mechanical Sewing Machine
I need a walking foot for a Necchi Model 4795 for Quilting.
http://www.sew4less.com/product/2034/Low_ShankEven_Feed_and_Walking_Foot_and_Quilting_Foot_10449
Jan 12, 2009 | Necchi 4595 Mechanical Sewing Machine
Necchi 4595 Mechanical Sewing Machine Logo
156 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
