Question about Hero rc h288 3 channel mini indoor co-axial helicopter w/ bonus
The top rotor for hero rc h288 won't spin.
The top rotors will not spin unless held upside down.
  • 3,204 Answers
Cog spring as come off or snapped keeps the cog in place.
Posted on Dec 27, 2013
Top rotor will not spin
I have the same problem. I have two of these helicopters and just recently brought them out of the closet. On one of them, the bottom rotor spins but the top does not. On the other, it Ian the other way around. It seems like the shaft is not catching the rotors properly, anyone have ideas?
Dec 25, 2013 | Brookstone uControl Cloud Force RC...
Why won't the top rotor of my phantom rc helicopter spin?
must be not tight enough when attached to the metal shaft connected to motor, metal shaft may be spinning but not the top rotor, find a way to tighten it down on the metal shaft.
Nov 11, 2013 | Toys
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
Top blade wont spin help.
the top blade should not spin unless the main rotors are turning as this gives the copter forward and sideways movment it should be secured with a small grub screw to the main shaft
hope this helps
Aug 08, 2011 | RC Remote Control Rc Helicopter
The tail rotor will not work. The tiny motor is not working so it does not spin the rotor. What can I do???
doubld blade rotor there is no need for a rear/tail rotor, on the remote are 2 buttons they will control Left/Right spin , adjust so that it does not spin around
Feb 05, 2011 | JCPenney Gyropter RC Helicopter
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Heli wont go up very much and turns to the left
If thi is a Reflex with two opposing rotors and two directional fans then use the "trim wheel" on the top of the rotor assembly to counteract the spin. If you crashed it often enough the shaft for the top rotor may have come loose. I'm not sure how this actually works with the trim wheel but mine crashed a bit and the shaft came out. I re-inserted it and it worked OK for a while but eventually the gear inside stoppped grabbing the shaft and the top rotor would not spin. I took it apart and tried gluing the gear to the shaft and that got the rotor to spin at the same rate as the lower rotor but I could not trim to get rid of the spin on the body. I would advise not buying the Reflex becuse it does not hold up very well. I went out and purchased a Sharpshooter which is easier to fly and seems more durable
Jan 12, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Hero rc h288 3 channel mini indoor co-axial helicopter w/ bonus Logo
142 people viewed this question
Top Hero Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hero Toy Expert? Answer questions, earn points and help others
