Question about New Bright Small Holiday Express Train
Train wont smoke
Bougt train brand new,but it will not smoke.how do i make it smoke?
Unit will not smoke, this is the second time I ran train.
have you added the correct amount of smoke oil to engine ?
part number 6-37841 lionel
Dec 29, 2015 | Lionel 31960 The Polar Express O Gauge...
The smoke unit stopped working. been run only 5 minutes
??? not sure why a evolution would have a smoke unit in it , but anyways its possible that trains were shipped with only a small amount of smoke fluid in them (makes shipping less messy) a bottle of smoke fluid and a few drops of this wonderful stuff is all you should need to get your engine smoking again
Aug 27, 2015 | Lionel Canadian Pacific Es44ac Evolution...
Smoke unit doesn't smoke
First verify wire connections (use a Volt/Ohm meter if you have one). Second, verify RESISTANCE in the smoke unit coil wire. Chances are it will be "Open" and reading zero (0) resistance. Acquire new wiring through eBay or Amazon ... and re-wrap the wiring as per the number of wraps as per your Lionel Repair Manual.
Apr 06, 2014 | Lionel 8141-50 Smoke Unit
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
Hi I have a Rio Grande Train set that I bought for my son. The train works but is not responding or working when we use the remote . Ive out brand new batteries in the remote the light comes on when we...
Look for a small opening with little white tabs that can be moved up and down, on both the train and the remote. All the tabs must be in the same position. ( Same thing on a garage door opener.)
If that's not it, make sure the batteries are in correctly in both items, reversed batteries will run lites and such, but not remote controls.
Nov 22, 2013 | Scientific Toys North Pole Express Xmas...
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
New bright santas christmas express no, 187 train wont smoke
This goes back about 40 years for me. Both Lionel and TYCO had "smokers" in their train sets. My recollection was that the "special smoke oil" was a mixture of very highly refined kerosene and parafin wax. Try a hobby shop such as Hobby Town or some such.
Nov 27, 2012 | New Bright 384 Holiday Express Animated...
Polar Express locomotive will not smoke with smoke fluid in stack and smoke switch on.
You may have to check if there is power to the heating element. You can also check to see if there is too much fluid. You can also put the engine in neutral and tap the chimney hole a few time to kind of "prime" the smoke unit.
Mar 16, 2011 | Lionel Polar Express Train Set
New Bright Small Holiday Express Train Logo
19 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
