Question about Imation (11762) LS-120 (SuperDisk) Storage Media
Imation LS120 I have several LS120 Imation super disks with data, but no drive available to read them. Are you aware of a service that can transfer data from an LS120 super disk to a standard floppy, cd, or dvd?
    Brigadier General:
  • 10,406 Answers
My computer has such a drive (120 Mbytes/disk).
As a "random act of kindness", I will read them, and burn the files onto a CD-R. Reply to this message, if you wish to proceed.
Posted on Apr 23, 2009
SOURCE:
Are there replacements available
There are, but the problem is connecting them to modern computers as the connections to the motherboard are SATA rather than IDE. The only way is to put on into a hard disk enclosure and connect it via USB. I have a proprietary made one when I go my laptop.
You should be aware that any Floppies that you have, that you or someone else has put data on are probably corrupted and unreadable. No one realised that the data would vanish and that is whey memory sticks came into being. Also 1.44Mb versus 5 Gigabyte, you choose :>)
I have an LS120 floppy siting on a box. 120Mb was so radically big when I bought it for £125.00 UK GBP! It reads both disks.
Oct 07, 2015 | Computers & Internet
Can I use super disc drive with my mac book pro
If the drive has a USB interface, Mac OS X will support it.
Mar 17, 2014 | Imation Sd-usb-m2 Superdisk Ls120 Floppy...
I need a driver for Windows XP and Windows 7. I have the parallel port version of the LS120 drive, brand: Imation It seems that nowadays this is almost impossible. I found one site that asks me to pay...
You might consider downloading a Linux LiveCD (such as Knoppix), boot to it, and see if Knoppix detects the LS-120 when connected to the legacy computer via parallel port. Make sure that the parallel port is enabled in the BIOS. From there, you can transfer the content from the disks to a flashdrive or external hard drive. My assumption is that you want to retrieve the data that are on these disks. In most cases this ancient hardware should be deprecated once data retrieval is complete. From my experience, the Knoppix DVD is more compatible than the CD version.
Paul Ronco
Jan 29, 2018 | Imation (11762) LS-120 (SuperDisk) Storage...
My louck flash is formated and now i can not use the space what do i do?
Your Imation Swivel Flash Drive comes formatted and ready to use right out of the box.
If you will be using the drive exclusively with Macintosh computers, do not format the Imation Swivel Flash Drive. The formatting message appears if your Macintosh has not yet been set up to read Windows-formatted files. Refer to your Mac's user manual to learn how to enable Windows file read functionality.
Also, be aware that when you format your Imation Swivel Flash Drive with NTFS, you will not be able to store as much data as your would without formatting. The format file used by NTFS will use some of the available space on the Flash drive - for instance, on a 128MB Imation Swivel Flash Drive, you may lose up to 8MB to the NTFS format files.
How do I format my Imation USB 2.0 Swivel Flash Drive in Windows? Your drive must be set up as a single public partition, since neither Windows Explorer nor the Macintosh OS will recognize a password protected partition.
To format the drive in Windows:
  • Go to My Computer
  • Locate the corresponding drive letter for the Swivel Flash drive (i.e. removable drive F)
  • Right click
  • Choose Format from the menu
A dialog box will come up and allow you to format your Swivel Flash Drive. Depending on your operating system, you can choose to format the drive in FAT, FAT32, or NTFS.
How to I remove or resize a partition on my Imation Swivel Pro Flash Drive? To resize or remove a secure partition, you will need to do the following:
  • Open the Flash Manager software on your hard drive
  • Choose Create a partition
  • Move the slider to zero (0)
Why don't I see a drive letter for my Imation Swivel Flash Drive?
This problem occurs if you map a network drive to the first available drive letter following the drive letters for the local volumes and CD/DVD drives. When you install a new device or volume, a software called Mount Manager tries to assign drive letters to the new volumes. But since the software does not recognize mapped drive letters, it assigns the next available local drive letter to the new device. This causes a collision with the existing mapped network drive.
Since the problem is related to your Microsoft operating system, they are your best source for resolving this issue. For more information, click here.
Dec 05, 2010 | TDK (CD-RW74HSFXS5) Storage Media
My 2.5 Imation Portble (Model # Apollo 25 PHDD - 160 GB) is not working. The laptop, PC nothing is reading it. The blue light comes...but thats it. I had taken a hard disk to take care of data that i would...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Imation Apollo (27223) 250 GB USB Hard...
(11762) LS-120 (SuperDisk) Storage Media: I have an older USB LS120 Drive and need the drive...
Download the software for drivers at
www.driverrobot.com
Use the following activation code :
DACG-KCCJ-AEB2-P52W-TATA
Run a scan with the software and install all the drivers you need.
Enjoy
May 18, 2010 | Imation (11762) LS-120 (SuperDisk) Storage...
IMATION Super Disk. MODEL No SD USB M3. SERIAL NO 10152 16632A
Define "no tworks"?
When you insert a disk, do you hear it spinning?
If it does spin, does it transfer any data from the disk into the computer?
Aug 21, 2008 | Imation (01946) External Floppy Drive
Imation superdisk drive
imation super disk SD-USB-M2.Solution to run under Vista service pack 1.Works for me
boot up your puter then plug in the imation super disk into your puter's usb port then into your power sulpply socket.Then if you have a reset button on your puter Press it
the puter then shuts down and resets itself when the screen appears it asks "Start up normally" Press enter.The drive is recognised and works.Its a bit of a ball ache but works for me.Hope this helps others with the same problem
JM.
Jul 12, 2008 | Imation (01946) External Floppy Drive
LS 120 Super Disk 120 MB Imation
hey there,
all i can say You make it a point to stay on the cutting edge of IT, so it's only fitting that your next support call is for a cantankerous old floppy drive. You're as far from the cutting edge as you can get, but can you still find the fix?The floppy drive is...
Feb 04, 2008 | Imation (11762) LS-120 (SuperDisk) Storage...
Data transfer
Usually your local Fry's, Staples, Office Depot could do the job for you (or even a local PC Tech).
Oct 17, 2007 | Imation (01946) External Floppy Drive
Imation (11762) LS-120 (SuperDisk) Storage Media Logo
197 people viewed this question
Top Imation Electronics - Others Experts
 Mike M
Mike M
Lawrence Oravetz
Paul Ronco
Level 1 Expert
Are you an Imation Electronics - Other Expert? Answer questions, earn points and help others
