Question about RCA Universal Remote 3 Device Remote Control
Gut schneid - RCA Universal Remote 3 Device Remote Control
Tip
DIY Replacement Ignition KeySubject: DIY Replacement Ignition Key Title: What to...
Title: What to do if you need a replacement ignition key
Overview:
There are times where you may need a replacement key. This can be the cause of a lost key, a key going bad, upgrading from the non all-in-one key to the all-in-one key.
Please keep in mind that if all keys are lost, there is NO WAY to program a new key to you car and a replacement TWICE module will have to be found with a key, either new (costly) or used and be married to the car via the dealer.
Symptoms:
Need a key, key is giving intermittent "bad key" messages and will not start the car, etc.
Experience Level:
Easy
Tools Needed:
Probably none, or a small tool to take the door off of a key via the hole in the side for the all-in-one key.
Time Needed:
Not much.
Parts Needed:
Key Blank from Dealer about $40 This is cut to your car.
Key Top from Dealer about $40 This is the "key guts"
all-in-one guts from Dealer about $90
all-in-one guts from ebay about $30-$60
key door from dealer for all-in-one key about $15
Procedure:
There are a few cases that can be covered
Case 1: Non All-in-one key replaced by non All-In-One key.
Subcase A: Have a non all-in-one key that is going bad
Solution: The dealer will have a replacement top for the key. Get the top, replace the top of the key and have it reprogrammed for the car. Total cost about $40 + $30.
Subcase B: Replace with all-in-one key because they are neato and / or the other key is lost.
Solution: Order the "Key Blank" from dealer and obtain the guts for the all in one key from ebay or the dealer. Have keys programmed by dealer. Total cost about $35 + $30 + guts cost.
Case 2: All-in-one key replaced by All-In-One key.
Subcase A: Have key but is not working.
Solution: Get guts and have it programmed. Cost about $30 + guts cost.
Subcase B: Lost key, need a new key
Solution: Get Key Blank and guts and have it programmed. Cost about
Outcome:
Very nice. Replacing the non all-in-one with the all-in-one dramatically increased the range of the remote. over the banana style remote.
Notes:
- Replace the battery in the guts if you get them off of ebay.
- You have to have all keys and remotes to dealer for programming.
- The guts for the non all-in-one key do not have the remote guts
- The guts for the all-in-one key have the security and remote in one
- The key shaft from the ebay all-in-one key can be discarded
on Jan 17, 2010 | Saab 9 5 Cars & Trucks
I've gutted all my catalytic converters and car still wont accelerate smoothly or go over 80 mph
gutting the cat converters was not a smart thing to do
the ECM needs feed back from the sensors to regulate the air/fuel mixture and now you expect it to do the job with half the sensors removed
like trying to brush your teeth with no hands
replace the cat converters with new ones then run the fault codes to really find the problem area
May 05, 2017 | 2003 Nissan Altima
Someone brought me a Toro CCR 2450 Snow Thrower. This appears to be leaking oil from the muffler. My gut tells me bad mixture- too heavy on the oil- but I'm not an expert and can't say for sure....
Yes, your gut may be right on the fuel mixture. It may also be the piston rings are worn and need replaced. But you should definitely try the right fuel mixture first! Another way to back up the gut is to take the muffler off and look into the cylinder that way. If there is a lot of carbon build up in there, then you know that that is the problem. There will also be carbon build up in the muffler too.
Good Luck!
Jim
Aug 08, 2011 | Briggs & Stratton Tools & Hardware -...
Having trouble getting to the guts
the guts of what??? motor trans ???
Feb 21, 2011 | 1987 Porsche 911
2005-2007 Dodge Grand Caravans
Yes, it should be able to be reprogrammed to the 06
Jun 23, 2009 | 2000 Dodge Grand Caravan
Can a person gut the standard exhaust? And how?
NO real way to gut the muffler. Best option is to buy some straight pipes.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 1996 Suzuki GSX-R 750 T
Water temperature from shower is eratic
swap the guts between the two valves to see if problem persists. if the guts from the shower has the same problem in the tub, bad guts. if not and the tub guts have the same problem in the shower valve, the problem may be a water saver shower head restricting the flow too much for the valve to operate.
please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | Plumbing
Televison & Video Logo
18 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
