Question about Sunpentown SU-4010 1.06 Gallon Humidifier
Spt dual mist humidifier making noise while running
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
I have a sunbeam sul2512um ultra sonic humidifier . I have had it for a less than a year . When I turn it on it makes a very loud noise where the mist comes at the base . Is there anything I can do to...
unfortunately thats the noiise a humidifier makes perhaps there are less noiser models on the market now you know as time goes by so technology becomes more amazing.
Nov 10, 2014 | Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Hm2612-u is making really loud noise when running
Best solution is to take it back to the retailer for warranty repair or exchange.
Mar 03, 2013 | Holmes Homes HM2612-U Ultrasonic Comfort...
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Nov 02, 2012 | Vicks Cool Mist V400 Humidifier
HUMIDIFIER IS VERY NOISY AND MIST SPRAYS FROM ONE SIDE ONLY
You should have bought a Cleanaer! It's totally silent, reaches all corners of the room with its patented LiquidIon technology not only takes the bad particles from the air, but locks them out for good so they do not reenter the airspace when you cross the room or disturb the furnishings.
Feb 15, 2009 | Bionaire Humidifiers
Humidifiter doesn't humidify
have you checked the misting nozzle? if its clogged place it in (CLR) and let soak, I would try to run a little diluted (CLR) through the unit as well, to remove any calcium build up, that is the most common problem with most humidifiers, also check to make sure the pump is working, if not you will need to replace the pump, hope that helped
Jan 18, 2009 | Sharper Image SI491 Humidifier
Wondering if damage to Holmes HM500 humidifier is fixable...?
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Nov 22, 2008 | Holmes Products HM500-UC 1 Gallon...
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Noisy ultrasonic humidifire
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Mar 31, 2007 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Sunpentown SU-4010 1.06 Gallon Humidifier Logo
80 people viewed this question
Top Sunpentown Humidifiers Experts
Mack Baxter
Dennis
Are you a Sunpentown Humidifier Expert? Answer questions, earn points and help others
