Question about Hammering
Makita demolition hammer stopped working - believed electrical pblm
My HM1211 demolition hammer just stopped working - I have removed the handle to dismantle the motor section and found that the brushes are in excellent condition. I have also removed the motor from the worm gear and applied power using the switch and it again does not work. It is thus evident that the problem is with the motor unit and more than likely the switch itself - does anyone know how I can repair the switch and is there a cut-off? Thanks, Chris
  • 378 Answers
You have to use an ohmmeter to check it, you must check the continuity of motor coil after the switch terminal if in this point you have the reading less than 200 ohms, try checking it before the switch but this time you have to switch it on. If you have the readings continue to check it from the Power Plug. Most cases the problem is only in Power cord .
Posted on Jun 01, 2009
  • 80 Answers
Before checking the motor i would check the cord...
then check the switch
or at the switch i would disconnect the load side and jump it bypassing the switch(carefully)
if the brushes and the armature look good..check to see if the spring around the brush holder isnt burnt or cut...
last i would do a resistance check through the field windings...
Posted on Oct 02, 2009
Why don't my demolition hammer stop hammering
Because if the power is interrupted or the carbon brushes (motor protection tripped) or had jammed or enough working hours without care. or become hot to prolonged stress that not every type of hammer is suitable for a rotary hammer can only 1/5 turn to the use of time than a REAL demolition hammer.
Aug 16, 2014 | Hammering
Hitachi h65 demolition hammer I got power going to the switch coming out but engine will not work wont spin or hammer
Check the power is going to the brush holders and that the brushes are free to move back & forth.
Apr 07, 2014 | Hammering
Re assemble kango 501 drill
Contact sales@oasistools.co.uk
Jan 09, 2014 | Hammering
Kango 900 manual
Could be brushes, switch or wiring. Use a meter to see.
Nov 25, 2013 | Hammering
Dewalt demo hammer, when switched on the motor speed surges up and down constantly. What is wrong?
Check the brushes first. If they are worn or sticking they could cause this.
If the brushes are fine and not worn down then it is most likely the electronics/ variable speed module.
May 09, 2012 | Dewalt 15 Amp 3/4" Hex Demolition Hammer -...
My hm0810b hammers softly and smells like its burning
Stop running it! Don't use tools if they smell like something is burning. Often times you'll make it worse and will make the repair more costly. It could be as simple as replacing the brushes.
To check for worn brushes, remove the black metal cover on the bottom. Then unscrew the black plastic brush caps. Worn brushes will be very low and not have mush carbon left, have a broken spring, or may be sticking in the brush holder and aren't sliding in and out well enough.
If it's something more than that, take it in for repair.
Jan 09, 2012 | Makita HM0810B 11 lb. Demolition Hammer
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Jan 30, 2011 | Electric Demolition Jackhammer
Bosch 11316EVS doesn't star. Power cable is good What another issue is possible?
most common problems with these units is brush replacement, or even the on/off switch, I work for a home depot tool rental and are constantly replacing the brushes.
Oct 09, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
The hammer suddenly stopped and wont restart. No warning, no motor fluctuation. Is it likely to need new bushes? Had only been using it on floor tiles for less than 2 minutes. Now nothing. Depress the...
you can check the brushes and see what shape they are in. Otherwise you might have a wire burned off in the motor. Iv seen the connections to the brushes burned off before.
Apr 05, 2010 | Metabo MHE65 Sds Max Chipping Hammer
The methode of changing brushes of gsh 11 e bosch
AT THE UNDER PART OF THE DRILL HAVE 4 LONG SCREWS TAKE THEM OUT AND U WILL SEE THEM.
Jul 10, 2009 | Bosch Sds - Max Demolition Hammer
Hammering Logo
592 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
