Question about Music
Casio PX-400r DC Jack Replacement - Music
4 Suggested Answers
  • 5603 Answers
SOURCE: Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Posted on Jul 14, 2010
reyjoshua07
  • 1157 Answers
SOURCE: I've got a Casio Privia
Hi genoness1,
If you noticed that the pedal works on and off depending on the jack plug positioning, it is because the jack is already broken loose from the solder on the board. If the pedal that you are using can normally open as most or normally closed like Roland types, you can still replace the loosed jack. Unit has to be opened and correct jack replaced.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 19, 2011
  • 5603 Answers
SOURCE: I have a Casio PX-800
If that is one of the ones with a plastic "hinge/spring", breakage is usually fatal... keep cord and plug for junk box.
Posted on May 01, 2011
My casio px 130 power input is broken, so I took it apart. Now I'm simply looking to buy a replacement part (the power jack) and replace it myself.
recommend electronic component store. not sure which country you are from ?
in Australia Jaycar
You will need desolder braid
https://www.youtube.com/watch?v=htrcZuK_ZsY
https://www.adafruit.com/product/149
You will need solder
you will need a soldering iron
https://www.youtube.com/watch?v=oqV2xU1fee8
you need safety glasses
you need a steady hand
You can either remove the component first and take it to the electronic component store to find a replacement part
or take the piano to the store and open it up and show them the part you need to replace.
electrician will most likely not be the right person an electronic technician as the socket will be for a low DC voltage plug from an AC - DC adapter most likely.
Sep 13, 2016 | Casio Privia Px-130 Px130 88 Key Digital...
I have a Piano from Casio Named The PX830 BP.I also have a Sustain Pedal Model from Casio named the SP 33.Will connecting the SP 33 into the PX830 BP work?Please tell me if I have the wrong model.
Unfortunately, the SP33 pedal will not work with the PX-830BP. Casio lists that the SP33 will only work with the PX-150BK, PX-150WE, PX-160BK, PX-160GD, PX-350BK, PX-350WE, PX- 360, and PX-560 keyboards.
The PX-830 manual does not list the stand or the pedal unit as separate items if you need to replace them. The pedal unit has 3 pedals like a traditional piano. I wish that I had better news for you.
Feb 04, 2016 | Casio Music
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
May 01, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Head set jack broken off in hole
I would unscrew the case to fix it only if it is out of warranty. Take it back to the dealer. Casio gives 3 years or 5 years warranty depending on the country.
Mar 16, 2014 | Casio Privia Px-130 Px130 88 Key Digital...
Where is the midi connection on the casio px 700
At the bottom near the power jack.
You may need a Midi-to-USB "cable adapter" to connect to a computer.
Jun 04, 2012 | Casio Px700 Digital Piano
I've got a Casio Privia (PX-400R) keyboard and it seems that the pedal jack has gone out. It's the 3 pedal jack circuit board. I took the keyboard apart almost completely to take a closer look at the jack...
Hi genoness1,
Hope it helps.
Apr 19, 2011 | Casio Privia PX3 88Key Portable Stage...
Jul 13, 2010 | Casio Music
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
