Question about Replogle Globes, Inc. Intelliglobe
The globe doesn't respond to the pen
This just stopped working. we replaced the batteries in the pen. the pen lights up but when you press it against the globe or base nothing happens.
Edu Science Interactive Globe with Smart Pen
I kept getting the "there is no book data" message as well, and it was incredibly frustrating as there is not manual, no information online, and when I called Toys R Us, they just told me to return it.
What ended up working for me was to turn the pen on and point it to the area on the globe that says "Interactive Talking Globe", just above the menu area where you select the different functions (ie "country and ocean", "national anthem" and "major cities").
That changed the voice back to the original male version, and all of the functionality returned.
I hope that this helps.
Dec 24, 2016 | GPS
Globe turns on, but pen will not respond to globe or buttons
try replacing the cord to the pen, or find where the pen connects to the unit as it may have a loose connection :0
May 03, 2011 | Oregon Scientific Interactive Globe
Leap frog tag pen won't work any longer.
You can purchase new one from amazon LeapTV Educational Active Video Gaming for Kids. I hope this was helpful. cheers
Mar 03, 2010 | LeapFrog Tag Reading System
The stylus pen has quit working for the Leapfrog explorer globe model 58-000 Where can I get a replacement?
If you are in the US, you can call their Consumer Services number at:
1-800-701-5327
They will be able to help you get a new one.
Thanks for using Fixya.
Jan 21, 2010 | LeapFrog Leapster Electronic Book:...
The pen hs stopped wotking on our leap frog globe
1-800-701-5327
Nov 19, 2009 | LeapFrog Leapster Electronic Book:...
Leap frog globe pen no longer works
Either the wire is broken inside the insulation, or the batteries are dead.
Sep 17, 2009 | LeapFrog Toys
Genius MousePen tablet 8x6 Isn't responding to the pen.
Have you tried replacing the Pen battery? Maybe it died.
Mar 26, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
I need a stylus pen for a Leapfrog interactive globe
Simply call Consumer Services at 1-800-701-5327 to order a new pen.
Dec 22, 2008 | LeapFrog Leapster Electronic Book:...
Pen won't work on Quantum Leap Exporer Globe
ok, last night I was doing some research on my daughters leapster, its not a quantum leap, but maybe can be fixed the same way. I found out that you can "recalibrate" the machine. I used the instructions for the leapster, but here is what they said about the Quantum:
Turn the power on. Wait until you see the "Home" screen.
Find the small hole in the back of your Pixter unit above the battery compartment door. That’s the calibration hole.
Insert, push and hold the stylus in the calibration hole. Turn Pixter over so that you can see the screen. When you see two plus signs, remove the stylus from the calibration hole.
First touch the plus sign in the upper left corner with the tip of the stylus.
Then touch the plus sign in the lower right corner with the tip of the stylus.
GOOD LUCK, HOPE THIS WORKS FOR YOU, I ALMOST THREW MINE OUT TOO AND NOW IT WORKS.
Nov 19, 2008 | LeapFrog Leapster Electronic Book:...
Leap Frog Interactive Explorer Globe. My touch pen as stoped responding
I just to the screws out from the bottom of the globe and took the little panel off near the battery panel. The pen is wired in with a rca jack and if we cant find replacement pens for it...it would be easy to replace. Any suggestions
Sep 06, 2008 | LeapFrog Leapster Electronic Book:...
Replogle Globes, Inc. Intelliglobe Logo
172 people viewed this question
Top Replogle Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Replogle Audio Player and Recorder Expert? Answer questions, earn points and help others
