Question about Electronics - Others
Sony ccd f455e
Moisture condensation has occurred
4 Suggested Answers
cpt100
  • 154 Answers
SOURCE: Moisture sensor on sony ccd-trv87
Moisture sensor is on the main circuit board and to replace the sensor you probably invest $100-200 for repair. It's the sensor or component surounding the sensor which gone bad. No other way around it. Good luck.
Posted on Mar 14, 2007
Sniperpoin
SOURCE: Moisture symbol on very old sony cam
I have a CCD-F385E with the same problem i kept putting the tape in and out and it started working.
Posted on Oct 12, 2010
randy_w0rdr
  • 623 Answers
SOURCE: How do I fix/clean moisture dew condensation on my sony hdr-pj10 camcorder projector
Try putting it in a container of uncooked rice for 24-48 hours. The rice will draw the moisture out.
Posted on Jul 01, 2014
Jul 01, 2014 | Sony Handycam HDR-PJ10 Camcorder
Moisture error code sony ccdtrv40
I've had this before. It usually occurs when go outdoors from an air conditioned space. Moisture condenses on the headwheel which will cause the tape to stick... and THAT will make a real mess!
If you're in a hurry, remove the tape cassette leaving the camera open, and use a hairdryer on LOW to dry out the inside of the unit. Then allow the camcorder to cool down (not in the cool or air-conditioned room) before you use it.
In the future, you should take the camera out of the cooled area still in the bag several hours before you intend to use it. To hurry things along a bit, you can put in a sealed plastic bag indoors and then bring it up to temperature, but don't open the bag until has reached the temperature of the space in which you will be using it.
Mar 20, 2012 | Sony Handycam CCD-TRV40 Camcorder
Well i have a Sony ccd-f455e the screen is all white i have tapes with things on and i have tried to put on the tv but just comes up with the eject sigh and beeps! when i set the setting to camera it...
It has been stored for some time I would think. There were capacitor kits that cured this but they are no longer available from Sony.
Jul 14, 2017 | Cameras
It says that a moisture condensation has occured on my sony handycam
put it under sun light,for the moisture condensation, that will go,try it.
Mar 08, 2010 | Cameras
Nov 25, 2009 | Sony Handycam CCD-TRV81 Camcorder
HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction.
To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
Oct 25, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Sony Handycam CCD-TRV37 Code C:31:10
it is whats called moisture condensation. this happens when the camera goes from a cold to a hot environment very quickly, and vice versa. Simply leave the camera standing with the tape door open for about an hour, and then try again. If this does not fix it, then try cleaning the video heads, and make sure the camera is not in a humid environment, as this will also cause this to happen.
Dec 28, 2007 | Sony Handycam CCD-TRV37 Camcorder
Mar 14, 2007 | Sony Handycam CCD-TRV87 Camcorder
Electronics - Others Logo
35 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
