Question about Bosch Washing Machines
Bosch VarioPerfect - WAQ243D0GB Error E61
Error code E61 appears with beeping whenever I select any programme. The door will also not open
4 Suggested Answers
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Posted on Sep 12, 2009
  • 414 Answers
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Posted on Nov 23, 2011
richroth
  • 9472 Answers
SOURCE: how to unlock childlock on washing maschine model Bosch WAS32794ME. Error : F:00.Thanks.
You need to press and hold the OPTION button (<) for 5 seconds.
Posted on Oct 31, 2012
The mashine doesn want to go on 1200rpm spin. It just spin at slowly. Model: Series 6 Varioperfect
Mine does this if the load is unbalanced, usually when it's got heavy items in it like bath towels, mats etc. I have to stop it, open the door, rearrange the items and start the spin again.
Sep 07, 2016 | Bosch Washing Machines
How do your error E17 on a Bosch Maxx 7 varioperfect.
Hi Kerry, The same question was asked on this site back in March 2009 !! and the link below has an answer..... CHEERS..
E17 error code Fixya
Apr 04, 2016 | Bosch Washing Machines
Machine shows E 61 when switch on.
E61 I think this a door lock error code. When you close, the door it activates a switch which will allow the machine to start a wash programme. Conversely the first thing the selected programme does is activate a solenoid, to stop you opening the door before the machine is ready. Think spinning drums, small children and cats, or flooded floors. I digress, if that little switch stops working or the mechanism has moved slightly and isn't activated, the machine assumes the door is open.
Maybe not a great help but we have narrowed things down.
H
Apr 03, 2016 | Washing Machines
A bosch varioperfect error code E29
E29 indicates a fill error. If the door is locking then check water feed. Make sure water is on and hose isn't kinked.
Jul 22, 2014 | Bosch Washing Machines
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
F61 code door won't open
Error E61 is generated when the door is locked but open.
Switch the appliance off.
After 5 minutes, use a thin screwdriver to push the lock to the right and then release it.
Restore the power, close the door and try the machine on a spin programme.
If you are still having trouble after this, let me know what actually happens when you try to use the appliance. The more detail you give the better.
Hope this helps
Let me know how it goes or if you need more help.
Dec 05, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch logixx 8 error code 80
Unplug the unit from the wall for 5 minutes and see if it clears, if not call service.
Jul 21, 2012 | Washing Machines
Washing machine bosch maxx 7 varioperfect
Nov 23, 2011 | Bosch Washing Machines
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
286 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
