Brother ax 330 REQUIRE DAISY WHEEL
I AM FROM INDIA
  • 3,594 Answers
The Brother print wheels are all the same you need to know the type style you need I have some in stock but I have no idea of the shipping to India.
DickyO
216-269-3918
Posted on Mar 24, 2014
4 Suggested Answers
  • 329 Answers
SOURCE: Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Posted on Jun 12, 2008
bjwanddave
  • 3 Answers
SOURCE: DAISY WHEEL
typing "code" and "reset" sets it right to type
Posted on Aug 05, 2009
  • 25 Answers
SOURCE: reset code for daisy wheel
I've found a manual that will be useful for your problem, you can find it here - Brother GX-6750 manual
Posted on Nov 15, 2013
When i press a key a different letter appears
First tun it off and on. If no help, Make sure ribbon is not cuaght up in the daisy wheel. Daisy wheel petals may be bent. Change the Daisy wheel. Possibility you have
setting for language.
Feb 23, 2015 | Nakajima AX-150 Typewriter
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
The key I push is not the letter that prints
Many factors affect correct character selection. To isolate the problem, follow the directions below:
  1. Is the daisy wheel locked into the carriage correctly?
    1. Open the top, locate the black lever near the hammer and move it away from the platen.
  1. Lift out the daisy wheel. Inspect the petals to see if they may be damaged.
  1. Locate the small spring loaded pin near the center of the daisy wheel hub. If the pin is missing or sticking, or the daisy wheel has damaged petals, replace the daisy wheel.
    1. Look into the opening from where you removed the daisy wheel. Ensure that there is no debris in the area; use canned air to blow out the area.
  1. Reinstall the daisy wheel or install a new one if the old one is damaged.
  1. Remember to push the black lever towards the platen until it snaps into place.
  1. Close the top cover and turn on the typewriter.
    1. After the carriage moves to the left margin, insert paper, and open the top cover.
    2. Push the hammer forward until it presses the daisy wheel petal onto the paper.
    3. It will leave an impression on the paper; it should be a lower case "h".
    4. If the impression is any other letter than those above, the typewriter may require service.
  2. Examine the keyboard area. If there is any contamination, i.e. spills, pet hair, etc, the keyboard may need to be cleaned by a trained technician.
  3. If the problem is not resolved after these actions, the typewriter may require service.
Brother typewriters have a 90 day labor, 1 year parts limited warranty. For 90 days from the date of purchase, Brother International, or its Authorized Service Centers, will repair this product free of charge if defective in material or workmanship. After 90 days, and until one year from date of purchase, Brother will furnish, free of charge, a replacement part for the defective part of this product, you pay for labor.
If your machine is within Warranty, you can contact Brother Customer Support Center at (1-877-276-8437)
Apr 05, 2013 | Brother GX-6750 Electronic Typewriter
If i chaing the arbic how to chaing for english
Please turn the typewriter off.
Remove the Arabic daisy wheel.
Install the English daisy wheel and switch back to Keyboard I
May 30, 2011 | Nakajima AX-150 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
The hammer that strikes the daisy wheel is stuck in the forward position on my Brother AX-450. Is there an easy fix for this?
Sometimes it a minor jam and you can just put your finger in the hammer and pull it away from the printwheel. Don't force it there are a lot of plastic gears that can be damaged. If that doesn't work, try releasing the print wheel (like if you were changing it) sometimes that will release the hammer. Last "easy fix" is to cycle the power, Turn the power off and when you turn back on the carriage should reset its self.
Dec 09, 2010 | Brother Office Equipment & Supplies
Other characters...
I think there is a switch somewhere on the machine
which selects a different keyboard layout. Try all the
switches and see. It's just possible you have a wrong
daisy-wheel fitted.
Apr 17, 2010 | Brother SX-4000 Typewriter
BROTHER ELECTRONIC AX-22 RANDOM LETTERS
Check to see if there is a switch on the left side of keyboard for international or symbol printwheel selection.
Jun 17, 2009 | Office Equipment & Supplies
Brother GX-6750 Typewriter printing problem
have you tried chaging the daisy wheel with a known good one? If yes, have you checked to see if the hammer is in a good condition?
Jun 02, 2009 | Brother GX-6750 Typewriter
46 people viewed this question
jasbo
jasbo
