Question about Identity Office Equipment & Supplies
Eddie cintron fl. - Identity Office Equipment & Supplies
My portable goldstar airconditioner is showing E4 .What does this mean
E4 is a Display panel communication error.
Might have been something as simple as a Power Surge.
Power unit off for 30 minutes and then restart.
~Eddy
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Goldstar Heating & Cooling
Ritetemp model 8050c i have to reset it 8-10 times per day if it is set on 74 the setting will always go up to 82 and beyond.sometimes it will go up in minutes How can it be set to stay where i want
Are you using the "Temp Hold" to hold your temp at that temp or changing it without opening the panel?
(To change and hold the temperature until you return. .Open the door and push the TEMP HOLD button. The HOLD icon comes on. Push the UP or DOWN arrow buttons to set the hold temperature. .HOLD is canceled if MODE switch is moved, or by pressing TEMP HOLD again.)
~Eddy
Jun 14, 2017 | Heating & Cooling
I want to recover my old Password for vsc.dorisc@gmail.com/Help
Click the "Need help?" link on the Gmail sign-in page.
Aug 09, 2014 | gmail.com
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Top Identity Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Identity Office Equipment and Supply Expert? Answer questions, earn points and help others
