Haier air conditioner
ESA 3156 airconditioner. Have installed but only have a less than 1 degree tilt. Do not see how to get the recommended 5 degree tilt. Are we overlooking an adjustment?
  • 83 Answers
The 5 degree tilt is a recommendation so that the drain pan would not get flooded. Just make sure the outsied part of the airconditioner is lower or tilted.
Posted on May 18, 2009
Haier Model# HWF05XCK-L 5000 BTU window air conditioner is leaking underneath and spitting water out of the top. It was installed as recommended.
The problem you're experiencing is generally caused by the rear of the unit not being tilted down enough. 1/4" to 1/2" is the general rule. This allows collected water in the drip pan, to run to the rear of the unit, where the drain hole is located. It would also be prudent, to check the drain hole under the drip pan, to see if it's clogged. It can be cleared with a pipe cleaner.
Hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Haier Heating & Cooling
My window airconditioner sounds like it has water in it and now its spitting out water in the room?
This can be caused by 2 things:
The drain pan hole is clogged and water is backing up in the pan. Look under the outside part of the AC unit for the drain hole and clear it. It may be hard to find, as the clog will blend in with the hole.
The unit was installed incorrectly and the outside portion (outside the wall) of the unit is not tilted down 1/4" to 1/2". Which allows the water to run to the drain plug.
Correcting either or both of the above 2 things, should solve the problem.
Jul 15, 2011 | Haier Heating & Cooling
When the airconditioner is on cool.Water comes from the airconditioner inside and dripping on the floor.
If it's a car air conditioner, your condensate drain line is clogged. If it's a home window unit, it needs to be tilted outward more. The downward tilt should be no less than 1/4" per foot. If your unit is 18" from the window to the back of the unit, the back should be 3/8" lower that at the window....minimum.
May 14, 2011 | Mitsubishi Heating & Cooling
Just moved and installed my LG airconditioner. it does not cool, but warms.
Check it's in cool mode and temp setting is 3 degree less than room temp Check compressor is working with required pressure.60 PSI@ 98 degree Fahrenheit of ambient temp.If less pressure or no pressure, gas leak. Arrest leak and recharge gas.
Jan 28, 2011 | LG Heating & Cooling
Hi my name is Tom, The problem I have is my airconditioner runs and i've also cleaned filters, but it only blows nomal air...it dosen't seem to cool...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
Thanks. Helpful?
Jan 03, 2011 | Heating & Cooling
My air conditioner doesn't produce cold air anymore
It is not enough btu`s most likely,but you can dissasemble the unit and clean it,and the coils.
Jul 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Kenmore air conditioner is leaking
Your A/C have to be tilted to the out side of the windows!!! It will drain it self to the sidewalk.
Do not set your A/C horizontally perfect!!!
It has to have tilt up to 15 degrees to the outside of a window.
Outside should be lower than in side.
Aug 19, 2009 | Heating & Cooling
Haier window airconditioner cooling is not effective
there is a temperature sensor bulb in front of the evaporator. check if it is too near to the coil. move iit away about an inch.
Apr 30, 2009 | Haier HWR12XCB Air conditioner
Airconditioner
Call 1-877-337-3639. or type in haier units ..then go to or type in http://wwwhaieramerica.com/ techsupport.
Sep 06, 2008 | Haier Energy Star ESA3183 Air Conditioner
Switching from air conditioner to a haier heat pump
(only the control wires from the thermostat to the inside and outside unit.A regular airconditioner has a 4--5 wires control and a heat pump has 7--8 wires control..!
Jun 02, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
