Question about LG 60PZ550 3D Plasma TV
PIC ON L G TV COMES ON AND OFF - LG 60PZ550 3D Plasma TV
My 32in tv comes on but the pic. keep rolling
Check and replace its main digital board. It is faulty.
Jul 04, 2013 | Emerson Lc320em1 TV
No pic no sound, but power on
Apparently power is getting to your TV but the internal power supply has failed
May 18, 2013 | Toshiba 55G300U TV
I turn on the Tv the sound comes on & the picture is blank Cablevision was here & said it's a problem in the set
He is probably not an expert (just kidding, of course he's not..) First, try connecting the Cablevision Box to another TV (if you don't have another HD TV, use the yellow/white/red Composite connection.) If there is still no picture, the box is no good. If there is, then try a different output from the Box or other inputs on the TV. Are you using HDMI (HD connection) out of your Box? Is the TV 720p or 1080p? Set the Box up (from the menu) according to the specs of your TV. Hope I helped.
Jan 11, 2011 | Samsung Televison & Video
Tv will not stay on but if u turn it on,green light comes on and you hear tv click on but goes back off....
how are you connecting your tv to view programing? the cable/cables that connect from your receiver to your tv. are you using a coax cable? are you using rca? are you using hdmi? the first pic is a coax cable, the second pic is a rca cable and the third is hdmi.
Nov 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light comes on but no pic or sound...is this repairable?
This is repairable of course, but I can't tell you the approximate price. That will depend on the number of components damaged inside.
Jun 01, 2009 | Televison & Video
Set dont like to be cold
Resolder all pinns on FBT on the Deflection board.
Jan 16, 2009 | RCA D61W20 61" Rear Projection Television
When set cold it doesnt have pic
check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Jan 15, 2009 | RCA D61W20 61" Rear Projection Television
Bush 42" rear projection rp40tv sound but no pic
any help please thanks tv turns on no problem but can not see any thing on screen. code comes up cant use menu do you no the code
Dec 16, 2008 | Bush 5693D 24" TV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
LG 60PZ550 3D Plasma TV Logo
24 people viewed this question
Computer Repairing
Computer Repairing
