Question about Dynomax 2000 - 2001 Oldsmobile Bravada Exhaust System Kit 19331 Olds
Trailer hitch wiring
Need help from good Oldsmobile mechanic. Have Trailer. Need to hook up wiring harness. Under rear bumper, seems to be extra wiring wrapped up. Is this 4 trailer, or do I need new wiring??. Trailer has 4 prong, in a row, pins. PLEAS HELP.!!
  • REDS Dec 26, 2013
    Asked before. Problem never solved! Need Olds. Mechanic!!
What wiring diagram I need for hitch to the truck chevy 1998 1500
GM trucks are prewired foe 4 wire trailer harness go to Autozone or other parts house and you can buy a direct plug in harness. GM just tapes the connector around the rear area near bumper on the harness.
Jun 11, 2014 | 1999 Chevrolet Silverado 1500
How do you hook up trailer lights so i can pull a trailer
If you bought the Honda hitch kit, a wiring harness and instructions are included. If you bought a different kit, buy the wiring harness from Honda. The harness connects to a plug located in one of the accesses panels in the back. You will have to take off the. Bumper facia to route the harness to the hitch. Be sure to use the rubber grommets to prevent the sheet metal of the rear quarter panel from wearing through the wire insulation and causing a blown fuse.
Aug 07, 2011 | 1997 Honda Passport
I have a 2011 victory cross country and want to hook up a trailer hitch what color wires do I tie into for the brakes, running lights and turn signals
Before you cut into the harness, look under the seat in front of the rear fender for a 4 flat trailer connector. I had a Victory in my shop last winter w/ a trailer hitch, and it looked to me like it was part of the factory harness. You'll need to build a whip long enough to get to the trailer-this one was wired through and stored in the left bag. If it's not there, contact me back and I'll look up the wire diagram for you. Good luck!
Jun 14, 2011 | Victory SM510R Motorcycles
Were do you hook up the two wires under the hood for trailer brakes on a 2000 silverado
Sometime around 2000, GM started putting trailering pre-wire harnesses in the vehicle. Your truck may have this harness built in and would greatly simplify brake controller installation. Look under the glovebox and see if there is a wire harness tied off. There will be four wires in this harness, which should be run over to the steering column to use it. Most trailer brake controllers are compatible with this harness.
The four wires in the harness are: Red, 12vdc; black, ground; blue or purple, brake pedal; and brown or white, trailer brake wire to seven pin, four pin, or five pin connector at trailer hitch, if your truck came from the factory with a trailer hitch.
If you are adding the hitch and do not have the four wire harness, the under hood wires from your brake controller are Red, connect to one of the studs under the distribution box cover (the distribution box is on the driver's side against the firewall. Underneath the cover are two large threaded studs which are hot from the battery all the time); and the other wire from your brake controller would have to be run the length of the truck along the frame, tied off in several places, to the trailer hitch connector on the bumper. Follow the directions that came with trailer hitch wiring connector to connect this wire to the proper pin in the connector.
If this has helped you, great, and please remember to vote/comment.
Feb 21, 2010 | 2000 Chevrolet Silverado 1500
I'm trying to hook up a trailer hitch and need to hook up tail lights to trailer
you may or may not have a trailering wire harness. look for an extra set of wires underneath the middle of the rear bumper (have a peek around the spare, too). this should have a flat plug on it that looks like it belongs on a videogame controller plug. some models also have a covered socket you should look for. if there doesn't appear to be one, you may have to have a professional or a knowledgeable friend put one in.
Jun 14, 2009 | 1992 Mazda B-Series
No power to tow wiring harness
hello, if the vehicle came with factory towing, i has the relay already....sometimes they ship however without the fuse. the fuse should be behind knee panel on driver's side labed TOW or TRAILER good luck, marty
May 27, 2009 | 2008 Mercury Mariner
I am looking for the wire under the rear of my 99 explorer to hook up the wiring harness for trailer or boat. HELP
From the factory there is an unused plug in the left brake light harness. You can get a tow light cable from Ford that's JUST for that, and its a 4 flat plug on the end. I 'found' mine in the compartment on the left where the jack is. Just peek in there with a light. It was still in the package. Otherwise call Ford, the thing plugs in and you route it down and there's a bracket to hold part of it under the bumper to an existing screw location.
-Cheers.
May 09, 2009 | 1999 Ford Explorer
Wiring for hitch
most of these trucks came with the wiring harness for trailers already there,look in the back whre the wires feed the rear lights,you should find a connector there, just go to your local parts place and tell them you need the trailer connector for your truck, should just plug in. if you need more help let me know Ray
Apr 15, 2009 | 2002 Chevrolet Silverado
Trailer wiring for 2005 Ford Escape without factory tow package
I had the sam problem with my '02 escape when I installed the hitch. I changed the turn signal relay under the dashboard on the drivers side of the dash with one from an escape that had a tow package(one was blue and the other was yellow...). worked fine for me after that. Don't know if it changed later...
Oct 17, 2008 | 2005 Ford Escape
Dynomax 2000 - 2001 Oldsmobile Bravada Exhaust System Kit 19331 Olds Logo
173 people viewed this question
Top Dynomax Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Dynomax Measuring Tool and Sensor Expert? Answer questions, earn points and help others
