Question about Rapid S30 Press Less Desk Stapler, Black/Red
Loading Staples into the Strong Rapid S30 Stapler
How do you load a ace heavy duty clipper stapler model number 82?
I found some information here:
ACE STAPLE Quality Tradition for Over 50 Years
It takes the Clipper Undulated Heavy Duty 3/8" Staples. On the back of the stapler, there is a loading rod. Remove the loading rod and place a set of staples in the chamber, then re-install the loading rod.
Dec 02, 2015 | Heavy Duty Tools & Hardware - Others
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
Rapid 90ec stapler
If you are a teacher, get a pair of scissors to get the staples out
Dec 01, 2013 | Tools & Hardware - Others
Paper pro one finger stapler
Chesspro5000 is right. You must open the stapler, pull out the slide, but instead of loading the staples directly on to the slide, you want to turn the stapler upside down and place the staples, face up, directly into the front of the stapler. Then, when you push the slide back in, it will glide directly across the staples and properly attach, rather than having to manually having to attach the staples to the slide yourself. Then close it back up and you should be good to go!!
Good luck!!
-Kelly
(Sorry for the repeat comment and any redundancy in my own message..!!)
Jun 04, 2012 | Tools & Hardware - Others
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Feb 08, 2011 | Tools & Hardware - Others
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Loading staples
Hi Sharon. It is absolutely essential that you get the staples designed for this stapler. These are Powershot 5700 staples.
please mark this answer as a fixya! thanks.
Mar 12, 2009 | Black & Decker 5700 Powershot Forward...
Rapid S30 Press Less Desk Stapler, Black/Red Logo
219 people viewed this question
Top Rapid Office Equipment & Supplies Experts
Bill Boyd
Ambrelle Amburgey
Ambrelle Amburgey
Level 1 Expert
Are you a Rapid Office Equipment and Supply Expert? Answer questions, earn points and help others
