Question about Dryers
Wcvh660hbb tub size - Dryers
What's the tub size for a maytag A-211
Which tub? You have the inner tub where you put your things to be washed, then an outer to that contains the water for the washing cycle. Which tub did you need the specs for?
Oct 18, 2013 | Washing Machines
1. Has anyone bought a 60"L x 42"W Almond Tub? Was it wider than the average household bathtub?
Yes I bought a 60"L x 42"W Almond Tub and found that itwas wider than the average bathtubs. Enjoy!
Jul 15, 2012 | Sterling 60"L x 42"W Almond Tub...
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
I bought my hot tub used it has no filter i need to no what size of filter it takes also what size of fuses does it use.it is a 220 volt do you know ehat size heater core?
Your tub needs to be hard wired through a 220 Volt 60 or more amp GFI by a professional electrician. Your tub needs to comply with your local codes.
If you will go to your local professional pool supply with dimensions of the filter cavity, they can provide you a cartridge.
The heater 'core' is a large calrod that sits in the water flow.
I hope this information helps you.
Thanks for your interest in FixYa.com
Aug 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Water leaking on fill , fiil hose is not leaking , appears to be comins out under tub
either your tub seal is getting bad between tub and transmission or your "water fill" tube to the "size of load" water fill control on control panel has a leak in the plastic tube
Aug 25, 2009 | Maytag Washing Machines
Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Mar 24, 2009 | Kenmore Washing Machines
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Oct 27, 2008 | Admiral AW22 Top Load Washer
Dryers Logo
16 people viewed this question
Top Dryers Experts
