Question about Keurig Elite K45 Coffee Maker - -
Won't heat or brew
Power light will come on but won't do anything else. No noise or heat
  • 1,511 Answers
The Handle must be forcefully be pulled down in the Kcup to make positive contact. If that is not done the maker will do nothing.
Posted on Jan 30, 2014
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Vienna Black suddently stopped working. No lights or anything.
the grinding noises are worrisome. Sounds to me as though something was in the wrong place, and once it worked for one cycle, whatever was left inside, or ??? would have frozen the unit. Sounds to me like you'll need to take it completely apart, to see what's causing the lock up situation.
Jun 01, 2008 | Saeco Vienna Espresso Machine
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
The heat water temparuture light will not go off contiunes to try to heat water i have unplugged overnite hoping to reset but it has not im dying here! I have to have coffee!!!!
"Power switch relay is going out"....uhhhhhm, how do I explain this, not only does that answer not help, at all, it makes little sense. The power switch would simply be the on/off N.O. contacts allowing power for the more advanced circuitry which is where the problem most likely is....it seems as if maybe the temperature sensor, or thermocouple in the chamber is not sending back a proper signal to the circuit board, this would cause the system (when activated in proper sequence) to constantly send power to the heating element when the machine is in that stage of brewing.
If the heat light is just on all the time from the second you power it on (regardless of whether or not you have added water, hit "brew" button lets say), then the system is just F'ed...well, it's pretty much f'ed anyway because they make their coffee makers so that you are unable to do ANYTHING with them, technically speaking....one could always use a hammer I suppose. So yeah, while I realize this answer won't get you your caffeine fix for the day, what I hope to accomplish with this "solution" is disprove the other dudes failed logic, and let you know your machine is most likely done for so call up Keurig and demand satisfaction. Make sure you run vinegar thru the system before calling because there is a small chance the mineral build-up on the thermocouple element is causing this improper temperature (4-20 ma) feedback.
What now Fowler?? I just called you out man. Tell me how I'm wrong.
Jun 24, 2012 | Keurig Special Edition B60 Coffee Maker
I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Elite K45 Coffee Maker - - Logo
322 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
