Question about Pool & Spa
8-152715-20pool pump wiring diagram
No start motor ac120 volts
  • 3,103 Answers
There should be a plate on the back of the mpotor that shows line connections..
Posted on Jan 11, 2014
2 Suggested Answers
MOTORWIZJ
  • 1383 Answers
SOURCE: need to trouble shoot a C4SL2N134 pump motor. need wiring diagram
WD40 IS A WATER DISPERSANT AND WILL CAUSE MORE DAMAGE THAN GOOD ,IT WASHES AWAY OIL AND GREASE.. YOU MUST HAVE THE START SWITCH SET ,IT SHOULD BE CLOSED FOR START AND OPEN WHEN RUNNING.. NEW BEARINGS ARE THE ONLY GOOD FIX . YOU CAN TAKE THE BEARING IN YOUR HAND AT A SLIGHT ANGLE AND SPIN THE ROTOR, YOU CAN FEEL ANY BEARING DAMAGE THREW YOUR HAND I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Posted on Sep 11, 2010
Wiring diagram for sx model
look on the side of the motor it has a diagram for both 240 and 120 if wiring 220 motor should already be wired if 120 volt you have to move the wires shown on diagram
Aug 27, 2014 | Pool & Spa
How do I connect wires to pump
depending on your incomming voltage look at wiring diagram on side of motor usually motors are wired from factory for 240 volts if 120 volts you have to change wiring or a switch
Aug 12, 2014 | Pool & Spa
I need to wire a SP2607x10
look on motor should be a diagram pump is wired from factory for 240 volts if wiring 120 volts you have to chenge the brown and white wire see diagram then black goes to F1 white goes to F2 where white wire is
Jul 08, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
How do you switch from 240 volts to 115 volts on magnum force pump
Is the motor a Dual voltage capable motor?
If so, the diagram for voltage change should be on the label.
It is also on the inside of the back cover were the wiring comes into the motor.
Most likely it is an AO Smith Motor that Jacuzzi used for their pump. The newer motors today are really easy to switch between voltages. There are 3 male spades on the back of the motor and a wiring plug with 2 female connections. You should easily see a diagram/bold arrow, for which 2 connections/spades are for 240 and which 2 for 120. Just lift and move the plug to one side or the other. 1 spade will not be used.
Take a look at the picture:
May 23, 2014 | Jacuzzi Pool & Spa
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 21, 2013 | Pool & Spa
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Pool & Spa Logo
14 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
