Question about Imperia 180 CucinaPro Pasta Motor
Need a gear for Cucinpro pasta machine motor
Can't find a parts list
My Imperia electric pasta machine in not getting power?
I would doubt that it's the electrical cord or plug, (though anything is possible.). I don't know this machine that well. It's possible that the switch is bad, but more likely I would think that it might be a fuse inside the machine.
Did it stop working while making pasta? Or was it working fine the last time, you put it away, brought it back out and now it's dead? Or is it a machine you bought new and it's DOA?
If it was overworked, it may have overheated and blew a fuse inside to protect the motor or other parts from burning up.
You might want to bring it to a local appliance repair shop that can take it apart to test things out to see were the disconnect is.
Jan 26, 2015 | Imperia Pasta Presto Electric Pasta...
Need parts list, need to replace a gear
The company is hard to get parts from. I suggest that you go online to eBay to get your parts.
Dec 26, 2013 | Imperia Kitchen Appliances - Others
Ronco pasta maker stops on the mix mode
Your motor most likely has a short which is making it go to a sort of pause. The machine motor (the whole machine part not the insides) can easily be replaced on eBay or I just bought a new motor at Goodwill for $6.99.
Dec 26, 2012 | Ronco Automatic Popeil Pasta Maker
How do I get a part for my Betty Crocker pasta machine model BC 1393
eBay has every part you can possibly need. Otherwise, measure the disc and then shop on eBay for the same size.
Oct 19, 2012 | NIB Betty Crocker Automatic Pasta Maker...
I need the gears for an Imperia rm220 pasta machine
Imperia-Parts.com sell all the internal parts for the RM220 electric and manual version, not to mention they do factory warranty works too. Check it out
Jan 06, 2012 | Kitchen Appliances - Others
I can hear the motor running but the component doesn't turn. This happened when I was trying to make pasta.
There is a good chance that the Worm Gear Follower has been stripped
(i.e. all the teeth on the gear are damaged). Download a copy of the
Repair Part List from Kitchenaid.com for your particular model.
Depending on which model you have, it might be an absolute pain
to replace it without the proper knowledge and tools, especially the
Professional 6 Series.
Jun 16, 2011 | KitchenAid Food Mixers
The first time I used my new pasta roller I seem to have burned up something in my Kitchenaid mixer. What happened?
First Question that comes to mind, is the motor even running. If it is and there is nothing visible moving, you probably stripped the gears in the head of the unit. If the motor doesn't run, the brushes may have coincidendally worn out. Need more information. Reccomend taking the top cover off while it is unplugged and checking the gears and brushes. The Plastic gear (When I got mine) was a bit pricey, but a lot cheaper than a new mixer. If you wore out the brushes, You may just want to consider a new machine since you evidently got a lot of use out of it. Almost everything is replaceable in the mixer
May 22, 2011 | KitchenAid Pasta Roller & Cutter Set...
I need a part for a freinds Popeil Pasta Maker. Can you please help. I can send you a photo of the part if it would help Thanks. Wayne
Here is the website for the Owners Manual which has some parts listed. http://www.ronco.com/_downloads/RoncoManual-PastaSausage.pdf
If your parts are not listed, you can write, fax or call as shown below:
Ronco Inventions LLC
21344 Superior Street
Chatsworth, CA 91311
(818) 775-4680
FAX: (818) 775-466
Mar 18, 2010 | Ronco Automatic Popeil Pasta Maker
Imperia 180 CucinaPro Pasta Motor Logo
29 people viewed this question
Top Imperia Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Imperia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
