Question about Imperia Kitchen Appliances - Others
Need parts list, need to replace a gear
Cucinapro electric motor #400-MO
    Champion:
  • 287 Answers
The company is hard to get parts from. I suggest that you go online to eBay to get your parts.
Posted on Jan 27, 2014
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
Replacement parts
Replacement parts are not available for any Nostalgia Electrics equipment. Sorry.
Jan 29, 2014 | Nostalgia Electrics CCP-509 Popcorn Maker
Kitchen Aid Burr Grinder
If the parts are not listed separately, the motor and gears are a completely separate assembly. A replacement motor (assembly) would include the gears
May 06, 2013 | Kitchen Appliances - Others
Nylon drive gear worn on one side
I have been told by the manufactutere that they do not make any replacement parts for their shredders. If it is less than a year old they will replace it.
Jun 20, 2010 | Aurora Electronics AS1018CD Shredder
KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Jan 29, 2010 | Food Mixers
My 1992 lexus ls 400 keeps stalling and idleis very low
Look for a small electric motor near the accelerator cable and near the top of the valve cover.
It's call IDLE AIR CONTROL (IAC) motor.
It's job is to increase the idle when load is added.
Example: turning on headlight,turning on AC.
Testing it is simple.
Warm up you car for 10 minutes.
Locate the IAC motor
turn on loads.....AC,headlights,etc
The motor should move the idle up
If the motor does not increase the RPM then it can be stick.
Try to give it few gentle taps to free up the gears.
It can be clean if your are up to it.
This electrical motor is very expensive. Please handle it with care.
The other trouble spot are
old accelerator cable
TPS Throttle position sensor
I will do a simple tune up and gas treatment before starting to replace any parts.
Please post reply on the comment window.
Oct 27, 2009 | 1992 Lexus Ls 400
Motor runs but blade does not move. Sounds like gear stripped or maybe clutch slipping.
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Jul 17, 2009 | Remington 111409 - 01 6" Branch Wizard...
I have a TroyBilt electric chain saw and need geardrive
Your manual downloads from MTDProducts.com. This is the parts outlet for MTD. Troy-built is listed here:
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_BuyMTDOnline_10101_19502_-1
I clicked"
PARTS CATALOG "Troy-Bilt" enter
FIND YOUR PART "OPTION 1:" click the wrench
Model Name/Number: I entered "tb4516" and your parts list appears.
Your manual lists this phone number 1 (800) 520-5520. Please try them if the above isn't satisfactory.
GL
Lou
Jun 03, 2009 | Desa International 100089 06 Electric...
Nemox Lux Burr Grinder
There are a series of gears between the motor and the shaft. Replacement parts are avaialble ad cafeparts.com under ascaso ibertal grinders. You will need to take the grinder apart to find the problem.
Dec 16, 2007 | Nemox X79751250 Electric Burr Grinder
Kitchen Appliances - Others Logo
187 people viewed this question
Top Imperia Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Imperia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
