Question about Sanyo R227 WiFi FM Radio
After return of a power outage, my R227 was rendered"dead", presumably because of voltage spike. Is there a fuse in the interior which might be open?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
Yes there is. It is just inside the back cover on the right side looking from the back. It is located at the end of the brown wire from the power input jack. It has a plastic cover over it and is a
T2AL 250 volt (2 amp slow blow) with pig tails on it.
Posted on Dec 10, 2015
Power cut last night and cannot get my TV to power up.
First check your circuit breakers. Also,If you are capable, open the TV and check the fuse inside. The power outage and the sudden spike in power might have tripped the breaker or blown the fuse. Good luck!
Feb 17, 2016 | Televison & Video
What do I do after power outage and monitor will not work?
If the device was plugged in when the outage started and / or when power was restored - it may have suffered a power outage related voltage "spike" (or instantaneous rise in voltage greater than it is designed to handle).
Unplug it for 5 - 10 minutes and reconnect. If it fails to function you may need repairs or replacement. Try a different monitor on the computer before condemning it - it may be a problem with the computer's video card instead.
Mar 11, 2015 | Computers & Internet
I have a Yamaha htr-3065 HDMI receiver that won't turn on after we experienced a power outage. When I plug the unit in I get a buzz sound from transformer but still won't come on. The fuse and power supply...
If you have any electronics experience you should check the diodes or the bridge rectifier in the power circuit. Look for burned components or bulged capacitors.!!!Always unplug the unit and wait a few minutes before attempting any procedure!! I have found that capacitors usually fail due to voltage spikes which can happen when power is reinstated after an outage. Always use surge protectors on electronic devices. They have a component called an MOV that will absorb voltage spikes and save your equipment.
Oct 03, 2014 | Audio Players & Recorders
Panasonic problems
Your home may have suffered an electrical power surge, check the end of the electrical cord, there you may find a built in surge suppressor with two buttons, depress the reset button. If one does not exist, then you must access the interior power supply and search for a low voltage electrical fuse. Inspect and replace if burned.
Dec 22, 2013 | Heating & Cooling
I have an HP Laserjet M3035 that has no display after a 2 second power outage.
Electrical spike may have toasted the circuit board. Common occurrence when power returns after outage
Sep 25, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
AFTER POWER OUTAGE IT IS DEAD
Voltage spike likely blew across the dielectric of several electrolytic capacitors. The internal fuse may or may not have survived. If it did not- replace it once and see if it is as simple as that, although you are likely looking something more.
If you want to try to salvage it, recap all electrolytics and tantalums. with new high ripple current types for the electrolytics.
Feb 07, 2012 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Can anyone advise what might be wrong with my Acer Aspire L100. We had a power cut the other night and it knocked off her computer. The unit will not restart and is completely dead. Are there any simple...
I am assuming you weren't plugged into a surge protector when you lost power. During power outages, spikes in voltage occur, so what happens is there's no mechanism to interrupt that spike by grounding, which surge protectors are designed to do. Any laptop/computer components cannot handle this voltage spike as they are delicate to certain voltage tolerances. I hate to say it, but your laptop is toast.
Jul 28, 2017 | Acer Aspire L100 PC Desktop
Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Processor
be more specific. Is the PSU powers on, Do you have any LED's on, any fans spinning, any sounds out.
Feb 11, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Sanyo R227 WiFi FM Radio Logo
419 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
