Question about Welding Tools
Manual for smith-roles "comet" stick welder - Welding Tools
I have a Craftsman Stick Welder mod. 113.20245
http://www.shopyourway.com/manuals/27720 good luck with cables they are discontinued. you may need to go to a welding supply house so they can size the connection
Oct 17, 2015 | Welding Tools
Need owners manual for miller maxstar 140 tig/stick welder
Contact Miller Electric on their website. If you want a Technical Manual, Miller doesn't sell those to the public. They're only available to authorized repair facilities. If you're interested in purchasing one, contact me with the serial & model numbers. I may have it in PDF format.
ToBIGWillie@aol.com
Aug 25, 2014 | Welding Tools
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
Im looking into getting a mig and have come across the century (by lincoln) welders for 299. is this a quality welder and of same quality as a Lincoln brand.
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
Jan 01, 2011 | Lincoln Electric LE 83180 Century...
My 180 MigPak will not deliver argon to the torch. The tank is turned on. But won't let gas flow when the trigger is squeezes. Stick the torch in water no bubbles appear. What could be the problem. ...
Your gas hose or torch could be bad or plugged. Your gas solenoid on the welder itself could be bad. Disconnect the torch gas hose at the welder and see if you have gas coming out of the welder itself.
Jun 28, 2010 | Lincoln Electric Lincoln Easy MIG 180...
Hello, Where can I get a users/owners manual for Linde UCC 305
Jessie email the owner of this site and see if he can't hook you up. He worked for Linde for 25 years.
http://weldingweb.com
Mar 12, 2010 | Welding Tools
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
Welding Tools Logo
74 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
