My toshiba satellite laptop P755-S5120 starts and I can see the toshiba logo and enter the bios menu by hitting f2 or the hdd menu with f12. After I select one of those options the system requires me
Computer gets stuck on a black screen, never loads to the login screen, not able to ever see the desktop.
    Top Expert:
  • Computers & ... Master
  • 22,688 Answers
I expect it is asking for the administrator password.
Posted on Dec 26, 2013
Testimonial: "Yes it is my admin password"
4 Suggested Answers
  • 73 Answers
SOURCE: Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Posted on Feb 08, 2009
SimpleText
  • 9 Answers
SOURCE: phoenix bios password
A direct way to blank out a BIOS password would be to remove the CMOS battery for a bit; I'm not sure where that would be in that particular laptop but commonly it is a small round flat battery
Posted on May 28, 2009
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
Posted on Jul 23, 2009
Automatic on toshiba p755
Not sure what system you are talking about. If you are saying that your Toshiba is automatically powering on then you may have a feature called wake on LAN enabled. Press the key at power on to go into your setup menu, look for the wake on LAN (sometimes called magic packet) feature under power control and disable it.
Feb 11, 2014 | Toshiba Satellite P755-s5120 Core I7 Pc...
How to reset toshiba bios
Just before it tries to boot press F1 or Esc and when it loads the bios select default. Press F10 and that's it. Basics are reloaded.
Nov 13, 2013 | Toshiba Satellite P755-s5120 Core I7 Pc...
How to factory reset my Toshiba satellite laptop P755-S5120, core i7, 64bit plese help me.
Go to BIOS setting through the Bios setting Key eg F2 and click on file then select set to Default.
Oct 04, 2013 | Toshiba Satellite P755-s5120 Core I7 Pc...
When starting it appears normall gives F2 and f12 option after that the screen becomes black
Was the laptop on? Projector on?
If so this = No.
Toshiba Satellite C600 specifications,
http://egadgetsclub.com/laptops/toshiba-satellite-c600-notebook-review-specifications/
Intel Pentium Dual Core T4500,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#NetBurst_based_Pentiums_2
Go to F2 option. That should be - enter BIOS Setup.
Look at the main menu (Which it automatically goes to)
Or use Down Arrow to highlight Standard BIOS options, and press Enter key.
Is the Harddrive listed? HDD0 has harddrive info listed to the right?
(HarDDrive0)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Computers & Internet
I use Toshiba Satellite L310. When i starting on the computer, i didn't see any command key to get into my computer BIOS. I just see a TOSHIBA logo.
Normally it's F2 to get into the BIOS, F12 to getr into the BOOT order menu. If you get problems loading, check that the LAN/Modem is connected (if it is wired), as the computer may need that items authentication before it will load Windows.
Oct 19, 2012 | Computers & Internet
If I want to add more memory beyond the 8gb max from the MFR, will it work?
You cannot add more RAM that the recommended max. specified by the manufacture.
If you could install more than it 8Gb, either the laptop won't work OR it cannot access more than 8Gb of RAM.
Sep 04, 2012 | Toshiba Satellite P755-s5120 Core I7 Pc...
How do I enter setup when there is no option to enter
F2 is your bios setup, and F12 is the boot order selection, if you cannot access the two options there is no other way. That shows up when the Toshiba logo is visable. If your windows run properly I would not risk formatting the hard drive. But it might be worth contacting Toshiba, customer and technical support about the unusuall situation.
Mar 14, 2012 | Toshiba Satellite A55-S106 PC Notebook
When i turn on my computer a black screen pops up saying enter current password._ Unable to use f2 or f12 What am I supposeed to do
Hi
You could try to start up in safe mode ( quite often f8 ) sign in as administrator and cancel the password
Also if you get into safe mode try a system restore back to when it was ok
Or hit delete key a few times when starting up hopefully this will take you into the bios because the f12 or f2 key may be disabled
Be very careful what you change in your bios because on a laptop its not very easy to change jumpers on bios battery so only enable the f2 or f12 then hit save and exit windows will then restart
But be very very carefull not to play around in the bios if you dont understand it you may end up with BIG BIG Problems
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba sattelite l300 crashed on my children when i tried to start again it would not witch on i tried in safe mode and worked i then have tried again and screen just takes me to restore computer. i...
Please do follow steps:
Switch your notebook ON
Press immediately F12 to enter boot selection device menu
Choose CD/DVD drive and press ENTER
When menu is shown and your language is marked confirm with OK
On each step just confirm with OK and recovery installation will starts properly.
ALL data on HDD will be deleted.
Jun 30, 2010 | Toshiba Satellite Pro L300 Notebook
Starting problem
not sure on model what f2 or f12 is
f2 enter bios
f12 choice menu
options:-
re-install xp
repair xp
flash bios
Jan 06, 2009 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
David Payne
David Payne
