SOURCE: Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
SOURCE: heater keeps turning on & off but no heat
What type of heater are we talking about? if its the home furnance, it sounds like the ignitor is coming on and shutting back down, the heat comes on ignite and the blower comes on like normal, then after a few minutes it will shut down, you will have to remove the ignitor, clean it with a little piece of sand paper to remove the carbon build-up, replace the ignitor and turn the furnance back on, this should correct the problem.
SOURCE: my amish heat surge heater
Sadly, the only thing that is Amish on your heater is the cabinet mantle. The electric fireplace is made in China. Never-the-less, from what you describe, it appears that the heater coil is not receiving power or it has burned out. If it's not receiving power, one of the resistors that controls the power to heater has gone bad (probably melted). The bulbs being burned out does not affect the heater. You must have had this unit for sometime for the bulbs to burn out. Normally these are LED Bulbs that have a tremendously long life. It may be that the bulbs have vibrated loose and need to be re-tighten.
If I recall correctly, these units were sold with a one year warranty and may have had an option of an extended warranty. If yours is still under that one year warranty, you're in business. If you purchased the extended warranty, that's even better.
In any event, contact their customer service dept @ 1-800-924-7964, as they may able to help you even more.
SOURCE: how to change bulb in amish heat surge heater
It's not difficult to change the bulb. But lengthy to explain. If you no longer have your Owners Manual go the link below and click on "Flame does not illuminate properly" More than likely though, the bulb(s) have just come loose.
http://www.heatsurge.com/help/troubleshooting.cfm
SOURCE: heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email [email protected]
