Question about Dometic RM2852 Refrigerator
Rm2862 willnot comeon at all,frot panel does come on , no blown fuse Lp turns on the heather but unit will not cool
  • Official Brand Answer
  • 73 Answers
If you fridge is level, and the rear coils of the cooling unit are warm then you more then likely need a replacement cooling unit. If you do, we can help. We are Arcticold Refrigeration. We specialize in the manufacturing of New Replacement Cooling Units for Dometic & Norcold RV Fridges. Our cooling units are direct replacements of the factory units. In most cases the cooling units can be changed in a couple of hours. Arcticold cooling units come standard with new installation hardware, installation instructions, and a lifetime warranty. We also offer 7 day a week free tech support 1-888-782-6665 Our cooling units are available throughout North America. Don't hesitate to give us a call or visit our web site. ArctiCold Refrigeration We keep it cold rm2862 willnot comeon at all,frot panel does come  - f926e66c-02f3-4d45-9004-f68d1864e268.jpg
Posted on Mar 07, 2014
2 Suggested Answers
SOURCE: dometic RM2862 will not come on at all, no blown
I have the same problem Have replaced the power Modular still Refrig light or anything styill doesn't work. Anyone have any suggestions?
Posted on May 21, 2010
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
It does not run on electric or LP gas
Check the thermistor by unplugging it from the main circuit board located at the back of the refrigerator. It will be the harness to the left that has only two wires in it. Unplug it and allow the refrigerator to run for 24 hours. If it does not cool after that then you have a bad cooling unit.
Dec 26, 2013 | Dometic RM2852 Refrigerator
Rudd model ukab-030jaz
You most likely have a small 3 or 5 amp fuse on the circuit board on the indoor unit that has blown. You should turn the power off at the main breaker panel and open the cover and very carefully look for a small blown fuse. It will look like one that you use in your car. Then if it is blown, replace it with the exact same size and rating.
Aug 17, 2017 | Heating & Cooling
Outside fan on heatpump not spinning
Are you cooling or heating? In the cooling mode the fan should run with the compressor. Shutdown, open up control section of unit, check Capacitor. Try to turn fan blades by hand. Does it spin freely? Do not touch capacitor terminals until you discharge it by shorting terminals to ground. If the capacitor looks swollen then it is bad.
Aug 08, 2011 | Heating & Cooling
Bosch13 gas tankless water heater no spark
Well if you don't have no spark,have you check to see if you got power?If you do have power ,the turn the water on to see if it will spark.If not the Check to see if the fuses are blown insde the panel.Most of them have fuses on the power coming in.If got all of that then you proablly wil have to replace the igniter board.
Mar 15, 2009 | Bosch & Tankless LP Hot Water Heater
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Dometic RM2852 Refrigerator Logo
136 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
