Question about Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T
Runs rough, backfires
Starts easy, runs rough
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Clean carbon on the spark plug
Posted on Dec 27, 2013
Testimonial: "Plug cleaned but no noticible change. Also changed oil and gas."
Why is my atv Honda fourtrax 350 backfireing
it sounds like its starving for fuel, when it runs lean you will get backfires and if its running rough then it may be starving for fuel at idle. Try adjusting you mixture screw and see it the engine will smoot out. Your carb my be dirty and not allowing enough fuel through it.
Feb 21, 2015 | Honda Motorcycles
Snow blower runs rough, backfires
Clean the choke asembly and air filter .
Dec 26, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Backfires and runs rough when letting up on gas.
the pulse timing ring in the distributor have it checked , the metal ring is held in place with platic studs and these studs get worn, then the ring starts to move. Also check the EGR valve
Jan 28, 2013 | 1992 Dodge Dakota
81 honda accord runs real rough and backfiring out of carb
That is a car not a motorbike. Bikes only have 2 wheels. But you may want to set up the cam and ignition timing. it is only timing that will cause backfires.
May 28, 2012 | Buick Skylark Cars & Trucks
HEVROLET BLAZER 2000 MISFIRING
Timing is off,problem with timing chain,also check fluids in ******,plus also if you have a distributer in your vehicle,if it is cracked,moisture getting in and ruining the points,-that is if your vehicle has a distributer! This will make a vehicle run rough as well.
You can have new plugs put in,but if your spark plug wires are cracked or worn,this will also creat misfire and backfiring.
Jan 25, 2012 | 2000 Chevrolet Blazer
Vstar 1100 idling rough and backfiring letting off the throttle
It sounds to me that your carbs might be a little gunked up - you mentioned the gas may have been old, so it's possible that the smaller (idle) jets are slightly plugged up. Fresh fuel might do the trick and/or you could try using a fuel system cleaner and water remover. This problem might 'solve itself' with a little time.
As far as the backfire - this might be either from the carb issue or it could be related to that rattle you mentioned - you could have a loose connection at or near the head - this can **** air and cause a backfire.
I hope this helped!
Jun 09, 2010 | 2003 Yamaha V Star 1100 Classic
1999 GMC Yukon seems to backfire once in a while
look for vac leak at egr valve, when cold spray carb cleaner on and see if it speeds up the eng
Jun 27, 2009 | 1999 GMC Yukon Denali
Kia problem
You should get the codes checked and start from there. My Kia Sportage was also backfiring and running rough, after checking the codes. It had misfires on two cylinders. I did a tune up and had to replace one of the ignition coils. Now it runs great!
Jan 01, 2009 | 2001 Kia Sportage
Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T Logo
225 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
