Question about Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T
Snow blower runs rough, backfires
Starts easy, runs rough
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Clean the choke asembly and air filter .
Posted on Dec 27, 2013
Have 11hp. craftsmen snowblower tecumseh engine model 031103, just cleaned carbeurator, IT starts runs a bit backfires and stops, what could be the problem
Is there an adjusting screw on the carb? If so turn to the left a little at a time and see if that corrects it.
Dec 15, 2016 | Garden
Troybilt snowblower starts runs good for 20seconds as soon as you are in heavier snow runs rough and backfires and sputter, just put on a new carburator, still doing the same
Hi Janice,
Sorry to hear you are having problems. If this is a 2-stage snowblower, they typically have a carb box that covers them. I would try running it without this, not as a permanent fix, but just to see if the blower performs better in the heavier snow. If it does, than it may be that the carb is in need of more air and might need an adjustment. If this is a single stage snowblower, then the carb still may need an adjustment. Not all carbs are adjustable and I know you said you just got a new one, but depending on how old a unit this is, it could be the problem. If you want to provide model/serial number of the engine, i can try to find it and see what kind of carb it is using.
Mar 06, 2015 | Garden
Snow blower runs well then dies to a rough idle
Sounds like it has dirt or water in the carb and is slowing down the fuel flow and starving the engine of fuel.
Feb 16, 2015 | Poulan Pro 27" 2Stage Snow Blower Electric...
Why does my weedeater start then it just stops running
sounds like the diaphragms in your carb need replacing. and clean your carb at the same time
Jun 05, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Running rough and backfire
Sounds like a timing problem(flywheel key) sometimes the key will shear part way do to wear, flywheel key is located on crank end under flywheel, disassemble air housing to expose flywheel crank nut unscrew nut (impact) to see key and keyway slot in crank determine that key is not sheard and is in center of crank keyway slot. if sheared you will have to use a puller to remove flywheel from crank. install new key and reinstall flywheel with an impact gun .
Mar 05, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Snow thrower backfires and stalls
sounds like carb needs cleaning or plug changed
id do both
Jan 30, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower
you need to thin out your mixture on the carb. should solve this.
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T Logo
383 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
