Question about Creative Labs MegaWorks THX 550 Computer Speakers
I need a wiring and mini din 9 pin connector diagram
Hello all I need a wiring and mini din 9 pin connector diagram for my computer speakers cambridge soundworks thx 550. Please i need your help.Thank you
4 Suggested Answers
SOURCE: Creative cambridge sound work megaworks thx 5.1 550
i lost my Creative cambridge sound work megaworks thx 5.1 550 cable.can i use any other cable?
Posted on Aug 23, 2008
  • 1833 Answers
SOURCE: I am trying to find
You can find audio control pod for creative gigaworks s750 system at http://www.blackmoreit.com/products/Parts-by-Brand/s750pod-creative-gigaworks-s750-7.1-thx-audio-control-pod.html.
For your wired remote for creative/cambridge thx 5.1 system visit http://www.blackmoreit.com/categorylist/creative/.
If you miss any parts, then you can click on "Contact Us" tab within these web-links and post your order. You will get the required parts.
Hope this will help you. Good Luck.
Posted on Jul 13, 2011
SOURCE: Cambridge Soundworks Gigaworks S750 I left the
I want to buy a speaker system Creative GigaWorks S750 Cambridge, 7.1, no matter if it is damaged javierarc@live.com
Posted on May 06, 2012
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Replacement part or schematic for Cambridge Soundworks computer speakers
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
Jan 04, 2013 | Cambridge Soundworks SWBE SoundWorks PC...
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
My woofer is not working as if there is a short somewere it comes on then when moved it goes back off
sounds like the contact points on your 9 pin DIN connector are corroded. If carefully cleaning each pin sounds like too much work, a search on ebay for a male 9 pin mini-din might bring you joy. But THAT solution requires some soldering.
Jul 13, 2011 | Dell HK395 Computer Speakers
Had my computer rebuilt and now my cambridge soundworks GCS300 speakers will not work....what do i do
Generally speakers will not need a driver, its more likely your soundcard needs the driver - have you tried anything else rather than the speakers to get sound? If you cant get any sound at all then its your soundcard so you will need the driver for it - otherwise try the link below, its the only thing that comes remotely close to a driver for these speakers -
http://www.bioticaindia.com/gcs300.html
thx, hope this helps :)
Jan 28, 2011 | Gateway Cambridge SoundWorks GCS 300 PC...
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Dec 24, 2007 | Gateway Edison Computer Speakers
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Creative Labs MegaWorks THX 550 Computer Speakers Logo
99 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
