Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Window and door rough out Openings
Just wanted to know how much to add to the rough out opening for windows and doors also what are the window and door schedules on blue prints do the tell you the window size plus the rough openings.
    New Friend:
  • 3 Answers
You really need to check with your supplier for your rough openings. Interior doors are fairly safe with adding 2" to the nominal width of the door and 1 1/2" to the height, but even these can vary a bit if you are using and odd jamb material. Exterior doors can vary depending upon the frame system and sill. 2 1/2" to nominal width and height is usually OK, but you can get into some real trouble. Window schedules can have either a unit size, rough opening or call size depending upon the architect and the brand of windows being used.
Posted on Dec 28, 2013
  • 468 Answers
Usually adding 3/4" to 1" to the actual window or door size (for a prehung door) works well. Blueprints can vary, some are the actual window and door opening ,some are rough openings. Usually rough opens will be followed by R.O. Hope this helps.
Posted on Dec 26, 2013
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: automatically adjust window size
You can get at least part way there as follows:
Go to Start>Control Panel>Classic menu>Choose Folder Options >General Tab, choose Use windows classic folders & Open each folder in its own window. Choose apply, Go to View tab and choose behavior desired for windows. Apply. Restart.
Beyond this, you could set a hotkey to minimize open windows, but you may have to get a third party program if you want automatic resizing.
See, for example, here and here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 24, 2009
  • 68 Answers
SOURCE: Using Window XP
hello friend
I think you are suffering from a severe virus infection. Try the following steps will improve the health of your computer
  1. you should have different partition for OS and data
  2. reinstall the antivirus
  3. get a disc of the windos Xp sp2 and with that in drive type sfc/scannow
thankyou
Posted on May 24, 2009
  • 81 Answers
SOURCE: A Google window keeps opening when clicking on options on FixYa
It is an adware run full system scan if that doesnot resolves issue.
do a system restore on earlier point where in the system was not creating this issue.
steps for system restore
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
Posted on Mar 27, 2010
Testimonial: "Thank U! Never used restore before, very helpful saying it was adware."
How do I replace and fit an extrior RH door handle to a 1995 Suzuki Baleno?
Open the door and remove the door panel with a special tool. Take out the screws on the door panel and any knobs or latches. Remove the panel. Cut the dust or noise seal, it is a messy liner that looks like paper or plastic. Remove the window hardware if you cannot get to the door handle screws from the openings in the door. Remove the window if you do this. Then you can replace the handle. Be mindful of the sharp edges that are present on the door.
Sep 12, 2014 | Cars & Trucks
Tip
1996 Acura TL 3.2 replace window motor
the motor for the window is a one piece unit that consists of the motor the cables and one of the tracks which the window slides up and down on.
begin:
under the door opening latch is a single screw, and within the door pull cavity is a single screw - with these two removed - you can pull those components away and then the door panel just pulls off - you'll have to remove three electrical connections, the courtesy light, the power window switch and the door lock switch and the panel will be free. Then you pull the water protection membrane off to expose the two openings that allow you access to the door cavity. If your window got stuck in the down position like mine did, you have to remove the 3 bolts that hold the window to the track brace - you also have to remove the window stops at the top to get the window out. With the window removed you can remove the 3 bolts that hold the motor and the 4 bolts that hold the track in place ( 2 top and 2 bottom ) - with this you can lay the motor unit on its side within the door cavity and articulate it out of the opening....replace the motor and go in the opposite direction to put everything back together.
HINT: It was a day or two before I could get the part from the part yard, I needed to be able to drive with the car window up... what I did for the time being to keep the window up was take the window stop clips and turned them upside down in the track to support the actually window stops with the window in the up position - worked out pretty well until I could get a door motor
on Jul 04, 2010 | Acura TL Cars & Trucks
Which place is good for buy Sliding doors and windows ?
There will be a window door manufacturing business in or close to your town . Check the local directory for this or go on the net and search for window/door manufactures.. Reputable companies will come to your premises and measure the openings and make the items to fit exactly.. Most hard ware shops only sell standard sizes which seldom fit properly as most doors and windows vary during construction.
Oct 26, 2013 | Cars & Trucks
Windows on passenger side front and rear won't work, up or down.
He could have been more helpful and explained it's likely some broken wires in the door openings. Check carefully the wire harness in the front driver's door and in the passenger front door, where wires get stressed the most when opening and closing doors. The driver's window switch is the master switch for all windows, check there and the other doors openings for broken wires. Splice back together any broken wires you find and recheck windows. Hope you find it. If not there, but somewhere else in the harness, you would probably need professional help to find it.
Feb 15, 2013 | 2004 Mitsubishi Endeavor
How do i install a new rear door window in a 2000 cadillac seville sts
You have to pull the inner door panel off, and work in the openings of the door there. You may have to raise or lower window to get to the bottom of the window glass's securing bolts to the channel. Once removed, the window, or what's left of it, can be pulled out through the outside of the door.
Dec 18, 2012 | Cars & Trucks
How to remove passenger side door panel, for 2000 Olds Intrigue?
1. Remove the door latch trim plate (coupe and sedan front doors).
2. Remove the ashtray (sedan rear doors).
3. Remove the seat belt retractor cover (coupe and sedan front doors). Use a suitable door trim panel removal tool to release the clip retainers
4. Remove the door lock trim plate and the power window switch, if so equipped.
5. Remove the window regulator handle by removing the inner retaining clip, if so equipped.
6. Remove the remote mirror control, if so equipped
7. Remove the trim panel retaining screws
8. Remove the door trim panel using a door trim panel removing to work loose the retainer clips.
9. Detach all electrical and remote mirror controls, as required.
To install:
10. Install the wiring harnesses through the openings in the panel, as equipped.
11. Position the trim panel to the door and align the clips. Press the trim panel to the door until all the clips are fully engaged. Align all the holes before engaging the clips.
12. Install the screws, remote mirror control and inside door handle bezel, as equipped.
13. Install the window regulator handle or power window switch.
14. Install the door trim plate, seat belt retractor cover or ashtray.
Dec 04, 2017 | 2000 Oldsmobile Intrigue
I own a 1994 honda accord and the window pane jams and goes off alignment when I winding it up,atimes it will stop working and cant wind up. How do I fix it?
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.Then you need to pull off the weather seal to get to the inside of the door. It sounds like the guide rails for the window have come loose
Aug 21, 2009 | 1994 Honda Accord
Cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Housing for Power Window Switches
you wont find it except a volvo and it may be unavaible by now ,if so try to by a used door panel with it included/try erie vo-vo
Aug 11, 2008 | 1991 Volvo 240
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
