Question about HP Compaq Presario CQ60Z Notebook
My laptop kicks everybody else off of the wireless router including the main desktop which is hard wired to the router.
My laptop kicks everybody else off of the wireless router when I turn it on. even the main desktop that is hard wired into the router.
  • 27 Answers
Perhaps its using its own address that is forcing the other computers to lose theirs. Under its network settings, make sure its set to DHCP. This means it will get an auto-IPadress from the router and not use its own one.
Posted on May 18, 2009
Having a problem connecting my wireless Laptop to my PCs wireless Router? Laptop will not connect but Tablets do with ease!!
you need to give a bit more information as to which OS you are using, if you are using win 7 go to your main machine and click start, and select "control panel" check you are viewing by "category" (top right), then under the "network and Internet" click "choose homegroup and sharing options" near the bottom you will see "view or change the homegroup password", make a note of this exactly as it is caps included, then on the machine you want to include in the network do the same and look for "join a homegroup" and type in the password you got from your main machine. that should sort it. If you get ipv6 errors use google to find the fixit from Microsoft. hope tha helps a bit.
Nov 27, 2013 | Computers & Internet
I need a key identification number for my laptop to connect to my Belkin wireless router.
you need to hard wire the wireless mondem to your PC then on the IE page in the header type 192.168.2.1, this will bring you to the belkin main menu. then you can manually ste up modem!
Sep 23, 2010 | Computers & Internet
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Does my main computer need a wireless card or just the laptop
The decision is yours, you can run either on wireless or wired.
Nov 03, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
Problems connecting my desktop
Press and hold the reset button on the router for 30 seconds. than turn the router OFF and turn it back On after 5seconds.
Than Restart the computer.
Please keep the post updated.
Jan 10, 2009 | Linksys WRT160N Wireless Router
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connection to my Desktop not working.
Try and change the cable from the router to computer with a new one and do the same with the modem and see if connects. Hopefully it's just the cables that are faulty.
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Need help
Is your laptop working completely -- including to the internet to access web pages with its current router attachment?
Is the laptop connected wirelessly or by a wire?
Is the desktop connected with a wire or wirelessly?
Was the desktop connected to another device before?
Was the desktop configured to login before especially if it was not connected to the router before?
Did you configure the router to do the login that used to be done by the desktop before, if that was the case?
If the router is now doing the login did you configure the desktop not to login if it is no longer needed?
Did you configure IP addresses, subnet masks, gateway addresses or DNS addresses into the router before?
Does having the router mean these should be removed and the desktop switched to accept dymanic addressing from the router?
These are quite a few questions and you may not be able to answer them all. Answer what you can in a comment to this issue and I will attempt to determine a plan to get your desktop connected.
Jan 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
HP Compaq Presario CQ60Z Notebook Logo
337 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
