Question about Toro Lawn Mower With Toro Power Tools
LOW OIL PRESSURE LIGHT IS ON AND WHEN YOU START MOWER ITS SHUTS RIGHT DOWN
    Problem Solver:
  • 9 Answers
First check your engine oil to make sure it's full.. If it is you'll need to replace the oil pressuer sensor...
Most of the time you can just unplug the sensor and tape off the wire to keep it from grounding ****BUT**** keep in mind that if the engine loses oil pressure it will not shut down and the engine will more then likly be destroyed.....
Posted on May 21, 2009
My Lincoln Continental 2000 Model oil light came on engine stopped after 25 feet. would not restart even though oil full. The car started the next day, but had a rattling sound at the top of the motor
Oil light is rather important it goes out if oil pressure is good comes on if oil pressure is low when it comes on damage is expected with continued operation like wearing of main bearings and pistons and cylinders can lead to a engine rebuild
May 30, 2017 | Lincoln Cars & Trucks
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
2000 Mitsubishi eclipse the oil light came on and my car shut down. I added 1 quart of oil and it was full but the car still won't start.
The oil light does not indicate the car is low on oil (based on your discription) it indicates the oil pressure is low, the no start is most likely due to this low pressure and the fuel pump has been cut off to prevent damage to the engine from low oil pressure. Please have a shop locate the cause of the low oil pressure warning and repair it as needed. It could be a false light or a real one, which means if you drove it very far you may have damaged the engines bearings.
Sep 24, 2012 | Cars & Trucks
2005 dyna low rider shuts down
It must be something about oil pressure. Or there is massive oil leek so you are on low oil level again or something with oil pump or filter.
Aug 20, 2012 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
Re my 2001 Toro Persal Pace Lawn Mower- The Engine Starts and only runs for 2-3 Seconds then shuts down. How to repair/ fix.
Could well be either you have low oil, or the oil pressure sensor is out. If it starts and sounds good then just quits this could be it.
Jun 14, 2011 | Garden
What will cause a truck to lose all oil pressure and the engine to shut off while driving down the road?
If wires came off oil pressure switch or if switch went bad, it would shut down truck immediately. Your oil pressure switch performs 2 functions; oil pressure to gauge.light and it's also a safety feature that if you're in an accident or rollover, when oil pressure drops it shuts off power to fuel pump. I'd start there. The reverse is also a possibility, if fuel pump fails, truck shuts down = no oil pressure.
Feb 28, 2011 | 1990 GMC Sierra
Stoped running when oil light cam on
oil light coming on usually indicates low oil pressure,your vehicle may have a safety device that shuts the engine down when the oil pressure drops to a dangerous level to protect the engine....hope this helps.....cheers
Jul 09, 2010 | 2003 Lincoln Aviator
Light comes on at start up and shuts off when
If you don't change your oil often the oil pump screen gets covered with gunk and will cause your low oil pressure light to come on, and I suggest you drop your oil pan and check because your oil pump can be damaged. Go to any auto zone and they will print out step by step instructions for you .
Feb 04, 2010 | 2005 Dodge Durango
Toro Lawn Mower With Toro Power Tools Logo
122 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
