Question about LG WM-2032H Front Load Washer
Load pop when running ,shuts down,smoke from back,burning electrical
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
You have a tub "Balance" bearing that is Shot! Goner! Dead! And your Tub may be a goner too! Depending on the extent of damage, you said you saw SMOKE! I never seen smoke from a washer unless someone throws a Concrete Block Stone in one on You Tube! ON PURPOSE! You have to weigh the age of machine vs the price of a new/USED one. If your machine is over 7 years old. Get a new One! Not a LG for goodness sake. Get a Whirlpool or a Maytag. I just bought a used one (Whirlpool) for $150. Still works 2 years later right next to the Dead $1600 LG I bought 6 years ago! The man I bought it from is in Rosamond, Ca. right by Edwards AFB. He has a garage full of them and guarentees his machines. There are a lot of people that do this. New is Not always the best!
Posted on Dec 27, 2013
Have a 1995 7.3 shut off while driving started back up when shut back off hard to start back up lot of smoke and would not idle and shut down when I let off pedal.
You could have a bad fuel pump there are 2 pumps one is in the center of the engine block and the other is on the driver side frame ...also inside the fuel tank is the sending unit which had two small filter inside it if clogged will cause no power under load and burn out pump
May 13, 2016 | Cars & Trucks
Eletrical Pop, smoke and stop
I just seen a recall list on many dryers, Home Depot listed it
Feb 18, 2014 | Maytag MEDX500XL Bravos X Front Load...
My 92 tempo gl smokes like crazy when i first start it and some times runs rouhg for the first mile then clears up and then drives fine???
The valve stem seals are probably shot, if it is blue smoke-oil burning. What happens is when you shut the car off, oil slips down past the bad seals and pools around the valve seat. Soon as car is started, that pooled oil goes into the cylinder. When you shut the engine off, oil under the valve cover will do the same thing again-it will pool around the valves because of the bad stem seals. A repair manual can tell you how to replace the seals without pulling the head off. An air compressor is necessary to keep pressure in the cylinder, so the valve won't fall down into the cylinder.
Feb 21, 2013 | 1992 Ford Tempo
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Washer smoking
If it's smoking you have a serious electrical problem in the unit. Unless you're experienced in electrical problems call a repair service for this one. It's not worth burning the house down to save money on this one.
Apr 26, 2010 | Maytag MAH6700AWW Neptune Front-Load...
2001 LAND ROVER, RUNNING IDLE THEN IT POPpED AND DIED. DOES NUTHN
Sounds like the timing chain or timing belt stretched, throwing off the valve timing, and then broke.
Jul 26, 2009 | 2001 Land Rover Range Rover
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
LG WM-2032H Front Load Washer Logo
108 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
