Question about TechFuel AC Adapter (ACNB90WC6943) for Sony Vaio VPCS117GG Laptop
How do i replace vaio vpcs117gg keyboard - TechFuel AC Adapter (ACNB90WC6943) for Sony Vaio VPCS117GG Laptop
Some letters don't work on my sony vaio
Check the keyboard. If it is defective replace it. You might want to hook up a USB keyboard to ascertain that the laptop keyboard is the one that is defective.
Aug 12, 2014 | Sony VAIO Notebook
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
When i turn on my laptop sony vpcs117gg windows show "prepairing your desktop" and when log on show vaio gate error and in this case logging windows is like safe mode? pleaz help me can i soleve this...
Have you tried press the F8 key before windows 7 starts and try last know good configuration, or tried to restore the system using system restore to a point before the problem occurred...
Aug 07, 2010 | Computers & Internet
Replace keyboard on vaio vgn-ns215
there are specific vaio notebook models where the keyboards cannot be easily replaced. that is the reason why their parts department do not sell keyboard parts. if that is the case, what you can do is to call sony to set up a repair for keyboard replacement or go to sony.com/repair if you want to process the repair online
Mar 31, 2010 | Sony Vaio VGN-NR110E/S Notebook
The following keys do not work. quipg'm Sony Vaio PCG-K33
remove the keyboard driver from the device manager and allow windows to reinstall it.
Dec 26, 2009 | Sony VAIO VGP-WKB1 Keyboard
VAIO VGN-C25G/B needs new buttons for the letter
The best way to solve your problem is to replace the keyboard.
Keyboard replacement are available on the Internet, I got one from this site :-
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Sep 28, 2009 | Sony Computers & Internet
How to replace keyboard on sony vaio VGN FW230J
This kind of replacement needs to be performed by qualified person. Better take it to the service.
Jun 24, 2009 | Sony VAIO VGN-FW230J/B Notebook
TechFuel AC Adapter (ACNB90WC6943) for Sony Vaio VPCS117GG Laptop Logo
46 people viewed this question
Top TechFuel Computers & Internet Experts
rancotech
Shashi Bhushan
Level 1 Expert
Are you a TechFuel Computer and Internet Expert? Answer questions, earn points and help others
