Question about Tempur-Pedic Furniture
Assembly The seat seems to be tipping forward. Is there a way to adjust it?
4 Suggested Answers
  • 3 Answers
SOURCE: Front driver seat adjustments.
I just had this problem fixed with a Tech 2 tool in my '03 yukon xl denali. The seat has a control module underneath of it that controls the 2-position memory, the power seat functions, etc. It needed to be reprogrammed - about $200 at the dealership, or free if you 1) have a good relationship with your service manager, or 2) own or know someone with a Tech 2 tool.
At first I thought it was because I had a Canadian model truck (the headlight switch is stuck "on" at all times no matter what position it's in, and the rear air controls are in celcius and not farenheight).
I'm assuming the switch worked before, and you may have encountered some sort of electrical issue (like a dead battery, or you gave someone a jump, you have a bad ground, you just installed an aftermarket stereo, you used a computer tuner, etc.).
Hope this helps!
Posted on Dec 30, 2008
  • 87 Answers
SOURCE: manual seat will not adjust,
get a junkyard seat it is just easy to go that route
Posted on Mar 12, 2009
97F350diesel
  • 1326 Answers
SOURCE: kia sedona front passenger seat stuck in forward position
Electric or manual??? If electric one of the motors has gone out. If the kids were playing with it they may have held the button down causing the motor to spin while the seat was all the way foward and it will just burn the motor up after so long. Also the switch could be bad. Unfortunatley being that its power there is no way to manually move the seat back without the motor turning or removing the seat and spinning the motor sprocket by hand...
Posted on Sep 10, 2009
The adjustable seat guides are rusted on my bobcat 553. How can I remove the seat to fix the adjustment?
remove the whole seat assembly
tip upside down and remove the retainers from the slides and pull the seat of the slides
get new seat slides and reverse the assembly procedure
Jul 19, 2016 | Seat Cars & Trucks
Tip
Level Seat tip
The most common cause of saddle discomfort is an improperly adjusted seat. Start with the seat level with the ground and only tip it from 2 to 3 degrees up or down if you think it will help ease discomfort. Don't make the mistake of angling it steeply downhill. This makes you slide forward putting too much weight on your knees and hands.
on Dec 21, 2010 | Cycling
How to remove back seat of hhr 2006
Rear Seat Replacement
showgif.do?image=1592810
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedure Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement .
Nut, Rear Seat (Qty: 6)
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N?·m (33 lb ft)
Bolt, Rear Seat (Qty: 3)
Tip
  1. Adjust the seat forward or rearward to access the bolts.
  2. Remove the plastic trim pieces to gain access to the nuts.
Tighten
45 N?·m (33 lb ft)
Rear Seat Assembly
Oct 28, 2015 | Seat Cars & Trucks
Move saddle forward
Undo the fixing bolts and the saddle will slide forward
Make sure to tighten it up
Mar 04, 2013 | Cannondale Cycling
GMC Yukon Seat Switch
You don't mention what year your Yukon is ? This could very well be a control Module problem .
I'll post how the power memory seat's work or are suppose to work !
Memory Seats Description and Operation
Battery voltage is supplied to the memory seat module through a 25 A circuit breaker. The memory seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the memory seat module the switch status is active. Each seat adjuster motor is controlled by the memory seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the memory seat module. The memory seat module operates the seat adjuster motors by switching one of a motors control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the memory seat module and are used to determine the seat position when storing or recalling memory settings. The driver seat adjuster motors use potentiometer type position sensors. The position sensors are supplied with a 5 V reference and ground circuits from the memory seat module. The position sensor signal circuits return to an analog input within the memory seat module. During adjuster motor operation the position sensor provides a voltage change proportional to the change in revolution of the adjuster motor shaft. The memory seat module monitors the voltage from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver door provides inputs to the driver door lock/window switch. Battery voltage is supplied to the memory recall switch assembly from the driver door lock/window switch. When a RCL 1, RCL 2, or EXIT switch is pressed, the switch contacts close the appropriate switch signal circuit to the battery voltage supply circuit within the memory recall switch assembly. When the driver door lock/window switch receives active switch signals from the memory recall switch assembly, the appropriate commands are sent to the memory seat module using the GMLAN Serial Data circuit. The Body Control Module software version determines the personalization features available.
Memory seat recall operation is allowed only with the transmission selector lever in the PARK position while the ignition is on. The transmission selector lever position data is provided to the memory seat module by a message through the GMLAN Serial Data circuit.
There are somethings listed you are not familiar with , like GMLAN Serial Data circuit ,maybe Body Control Module software etc... GMLAN is a communincation network that the computers on the vehicle uses to share information , transmit commons etc... you can google it to read about it .
There are DTC'S - diagnostic trouble codes that can set in the module in control . Do you know what DTC'S are .
DTC Descriptors
DTC B1825 01: Driver Seat Recline Position Sensor Circuit Short to Battery
DTC B1825 06: Driver Seat Recline Position Sensor Circuit Short to Ground or Open
DTC B1825 5A: Driver Seat Recline Position Sensor Circuit Plausibility Failure
DTC B1850 01: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Battery
DTC B1850 06: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Ground or Open
DTC B1850 5A: Driver Seat Lumbar Horizontal Position Sensor Circuit Plausibility Failure
DTC B1860 01: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Battery
DTC B1860 06: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Ground or Open
DTC B1860 5A: Driver Seat Lumbar Vertical Position Sensor Circuit Plausibility Failure
DTC B2355 01: Driver Seat Front Vertical Position Sensor Circuit Short to Battery
DTC B2355 06: Driver Seat Front Vertical Position Sensor Circuit Short to Ground or Open
DTC B2355 5A: Driver Seat Front Vertical Position Sensor Circuit Plausibility Failure
DTC B2365 01: Driver Seat Rear Vertical Position Sensor Circuit Short to Battery
DTC B2365 06: Driver Seat Rear Vertical Position Sensor Circuit Short to Ground or Open
DTC B2365 5A: Driver Seat Rear Vertical Position Sensor Circuit Plausibility Failure
DTC B2375 01: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Battery
DTC B2375 06: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Ground or Open
DTC B2375 5A: Driver Seat Assembly Horizontal Position Sensor Circuit Plausibility Failure
5) Memory Seat Module is under the front of the driver seat , you could look under an see if all the connectors are fully seated.
The best diagnostic step would be to hook up the factory scan tool an see what the computer is seeing as far as inputs from the switch an outputs it's sending . I wouldn't suggest you take the seat apart an try testing electrical inputs etc.... unless you very familiar with automotive electrical systems an circuits .
Mar 06, 2017 | GMC Cars & Trucks
2001 VW Beetle. The driver's front seat adjuster
I'm assuming you have manual adjustment seats. There is a spring underneath the seat that locks the end of the lever into corresponding notches in the seat frame rail. That spring has either fallen off or broken.
Jan 22, 2010 | 2001 Volkswagen Beetle
Driver's seat unable to move forward or backward
There are plastic gears connecting the track to the seat assembly. Whne one of these strip the seat will only work or move to one side. Infiniti does not sell a simple fix. You are looking at buying an entire seat assembly complete with the module for all the electronics. It will be at a cost of around $950 - $1000. Once that is in, Infiniti must program the seat to the brain of the car, only then can you reset your memory settings.
May 19, 2009 | 2004 Infiniti G35 Sport Coupe
Drivers electic seat will not adjust
I just had the same problem. When the seat is powered all the forward, one of the worm drives reached the end of its travel and jammed against the threaded block that it passes through. To fix this the seat has to be unbolted and tipped back. There are four tiny 6mm bolts that hold the motor plate in. Remove these and the motor will come out. The worm drive is bolted in at one end and has a set pin at the other. Remove the worm drive and use a couple of vice grips or equivalent to loosen the threaded block from the worm drive.
Mar 29, 2009 | 2002 Toyota Camry Solara
Manual seat will not adjust,
Mar 12, 2009 | 1999 Saturn SL
Passenger seat back will not move either direction
Motor on the seat may have gone out, contacts in switch got dirty or worn, or assembly reached limit and stuck. Try sitting in it pushing back hard and adjust. If not youll need to replace switch,b take seat apart to fix or replace.
Dec 06, 2008 | 1989 Mercedes-Benz 300-Class
Furniture Logo
83 people viewed this question
Top Tempur-Pedic Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Tempur-Pedic Furniture Expert? Answer questions, earn points and help others
