Scramble squares solution for elk puzzle - Televison & Video
How do you finish square squzzle puzzle
Here are some papers, code and blog posts (this is nice one too) on how to algorithmically search for solutions to squzzles/scramble square puzzles. You might have received one of these puzzles as a holiday gift over the last few years, they were quite popular.
C and Perl Implemenations
General Backtracking Approach
The algorithm is straightforward - just one that searches through solutions.
What's interesting is that I've seen people solve these puzzles, even brand new ones (no prior knowledge), very quickly. There's something that happens with a persons vision or something that's helping them not have to exhaustively search the full solution space. If I'd seen someone do this once or twice, I'd think it was just lucky picks. (these puzzles have enormous solution spaces (4^8 x 9! = 23,781,703,680 puzzle configurations) )
Is there something in this puzzle that "hints" to a human early in the solution testing that a solution is viable or not. That is, after 1 or 2 pieces placed, can the human see a promising solution "faster" than the basic algorithm that searches quickly through all piece placements and orientations. If so, what is that data ("hint") the human sees and how can we factor it into the algorithm?
Possible hint data:
Rules of thumb on how all these puzzles are printed and cut (do the puzzles all get made with same orientations so exposure to one puzzle provides data on other puzzles?)
Humans can see the whole pattern in parallel even when pieces aren't lined up so they don't have to check each piece systematically
Are combinations of pieces eliminated as the humans solve it thus taking them out of future solution attempts, reducing solution space the more the human works on the puzzle.
Thank You
May 30, 2011 | Google Computers & Internet
In the game hidden secrets their is a segment on matchsticks puzzle you have to move 3 matches and make 4 squares you cannot go to the side or down but can go up.the puzzle looks like a grid of 9 squares...
Matchstick puzzle, 4 squares moving 3 sticks. Move the left side matchstick from the top square that is on the left side of your screen. Place it on top of the square you just took it from. Move top and side stick on the square that is on the right top of your screen. Place them on top of the top square that is on the left side of your screen. You should see 4 squares
May 05, 2011 | Computers & Internet
Creat a romantic words with letters u i d n v h s e?
Welcome to Fixya. The answer to the puzzle is Husn Devi
In Hindi HUSN DEVI means the goddess of beauty.
Thanks for using Fixya
Mar 12, 2011 | Puzzle Quest: Challenge Of The Warlords...
What is the solution to puzzle number 100 please?
This continues to be the most commonly asked about Curious Village puzzle on FixYa (the search box is useful for quickly finding information)
As the hints state, all but one square is tilted and each pin can only be used once
The hints also give you the location of three squares and tell you the size and angle of another two squares
As an extra hint, none of the three small tilted squares mentioned in the hints overlap each other (knowing this gives you the location of one more square and just two possible locations for another)
From here, the rest should be easy (with eight pins to form two squares)
Make sure to use all the pins (all squares must have a pin in each corner)
A picture of the solution can be seen here if you need it
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle100.html
May 15, 2010 | Nintendo Professor Layton & the Curious...
Wooden piece puzzle square/rectangles various sizes coloured dots
it's okay I ended up finding the instructions. thanks.
Dec 23, 2009 | Puzzle Toys
On professer layton cant figure out were the 7 squares are
Go on youtube and type in: professor Layton and the curious village puzzle 100 and click on professor Layton and the curious village puzzle #100 seven...
and that will show you how to do it.
Jul 17, 2009 | Nintendo Professor Layton & the Curious...
Cant make sence of the way that puzzle 100 the seven squares are explaned
A Matthew Reynolds posted the answer to Puzzle 100 seven squares on February 27th. 2009. it must be somewhere in the system.
Mar 04, 2009 | Nintendo Professor Layton & the Curious...
Puzzle 100 in professor layton
This took me ages. Hope it not too hard to follow.
1st square is a small one made up of the top left four pins of the 1st and 2nd row,and is the only straight square on the board.
2nd square is made from 3rd pin top row connected to 5th pin 2nd row, then make a sq from here.
3rd square is made by connecting 4th pin top row to 3rd pin down on far right row, then make the largest sq from here.
4th square is made by connecting 5th pin top row to top pin in the far right row then make the sq from here.
5th square is made by connecting 3rd pin 2nd row to 2nd pin down far right row, then make the rest of the square from here.
6th square is made by connecting 3rd pin across on 3rd row to 4th pin across on 4th row, then make the rest of the square from here. Finally 7th square is made by connecting 1st pin 4th row to 1st pin 5th row, and make the rest of the square from here.
When I describe pins, I am talking about actual pins, not counting gaps where pin could be.
Hope this helps.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
