Question about Wowwee Robopanda Robot Panda With Mini Panda Plush
Robopanda won't move.
Robopanda talks but does not move. How can I troubleshoot this?
I have a 32cc model p3314 it starts but the chain won't move
If you are talking chain saw there is a safety clutch lever immediately in front of the top handle. this has to be back against the handle and when the chain jams you simply push it forward with your fingers and the chain stops
May 29, 2013 | Tools & Hardware - Others
Honda crv won't shift into gear
If you are talking about moving the console shifter, step on the brake first. If you are talking about a n issue where it is in gear and it is an automatic, check your fluid level. Then check solenoid wiring connectors and then the lower gear selector solenoid pair, It is easy to remove and clean. Located Front right passengers side of automatic tranny, 96 to 2002 Civics and Accords and CRV. Whack it on its face a few times and blow it out with a compressor. Use a pencil and a rag to keep from losing all your fluid when you take it off. Check the sound of the click with a 12 volt battery. Sometimes the solenoids get stuck if the fluid gets varnished or if it sits too long. The upper solenoid pair is not so touchy. Bottom solenoid will sometimes prevent starting out in first and will go straight to 2nd or 3rd from start. Also some creep in neutral when this solenoid is sticky. It doesn't move much when operational. A paper clip will move a solenoid plunger 1/8th inch.
Feb 04, 2013 | Cars & Trucks
Hey I need urgent help... My 1986 Tpyota Supra's
When you put the key in the door lock cylinder does the key turn freely in both directions on both doors (you should feel some restriction in one or the other direction). On the inside of the car can you manually unlock and if it doesn't does the lever still seem to move like it should. Or are we talking just the power switch.
Feb 02, 2013 | Cars & Trucks
My robopanda is in spanish
Use Translator for that prupose buddy
Dec 21, 2012 | Wowwee Robopanda Robot Panda With Mini...
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
Robopanada wont turn on
hi i bot robopanda sec hand and he was working fine untill i put new batterys 4 rayovac 4.0 aa batterys it worked just two seconds the everything whent dead and i,m unable to start him agine i even pushes the reset button im so un happy about this please please help me martin.
Dec 28, 2011 | Wowwee Robopanda Robot
Cx80, what does the code "rx" mean on the display
  • TX = Transmit. RX = Receive. Does your needle move when you key the mic? Does it modulate when you talk in the mic? Do you have an inline watt/SWR meter inline? What kind of a set up do you have? Mobile? Base? Get back to me if you want further help.
Regards, Tony
Oct 18, 2011 | Cobra 29 LTD CB Radio
If left unplugged fro the laptop for a few hours, or if the charger itself is moved from room to room, occasionally we get an issue where the green light that indicates power does not show up at all. The...
If light you are talking about is on the power supply itself, you need to replace the power supply. Look on E-Bay.
If the light you are talking about is the AC power light on the laptop, then there are two things that are most likely. First is the power receptacle in the laptop. I have personally seen many of these fail. The other thing is the battery. With the system Off, and power supply disconnected, remove the battery. Wait a couple of minutes and put back in and plug in charger. If it continues to happen then it is most likely the power receptacle in the laptop.
Best of luck, Jim
May 07, 2011 | Ultra Products ADP-65JH DB Ultra Slim...
Wowwee Robopanda Robot Panda With Mini Panda Plush Logo
Top Wowwee Toys Experts
Michael Vincent Cruz
Shekar Avadhani
Tom Chichester
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
